SmartEVSE script for car charging
Posted: Saturday 26 October 2024 0:34
by Tukker
I wrote a script for car charging using the SmartEVSE device.
Our EVBox is > 10 years old and I decided to make it 'smart'.
Michael Stegen gave me some clues how to open and change the EVBox and put the SmartEVSE device in place and it worked right from the start.
The script I wrote functioned like it shoud but I wanted to have it rewritten.
So I asked Microsoft CoPilot to do so.
The result is a script that goes beyond my programming skills, like the use of powerLevels in a table and the in pairs construct.
for level, power in pairs(powerLevels) do
            if availableEnergy >= power then
                newLevel = level
CoPilot added a time 'buffer' as well to hev the script not change the carging level for every single cloud passing by.
Here's the code:
        timer = {'every 1 minutes at daytime'}, -- at daytime
    logging = {
        level = domoticz.LOG_ERROR,
        marker = 'Car charging on PV Power',
    data = {
        desiredLevel = { initial = 'Off' },
        lastChangeTime = { initial = 0 }
    execute = function(domoticz, triggeredItem)
        local ChargingSwitchState = domoticz.devices('Charging Level').levelName
        local EVSwitch_16A = domoticz.devices('EVSE Switch 16A')
        -- Define power levels
        local powerLevels = {
            Off = 0,
            ['6A'] = 1400,
            ['8A'] = 1850,
            ['10A'] = 2300,
            ['13A'] = 3000,
            ['16A'] = 3700
        -- Get power level based on charging switch state
        local PowerLaadpaal = powerLevels[ChargingSwitchState] or 0
        -- Get power data
        local PowerReturn = tonumber(domoticz.devices('Power').rawData[6]) -- Solar power generation
        local PowerConsumption = tonumber(domoticz.devices('Power').rawData[5]) -- Home power consumption
        local availableEnergy = PowerLaadpaal + PowerReturn - PowerConsumption
        -- Logging
        domoticz.log('#1 Energy usage from the network: ' .. PowerConsumption, domoticz.LOG_DEBUG)
        domoticz.log('#2 Energy return to the network: ' .. PowerReturn, domoticz.LOG_DEBUG)
        domoticz.log('#3 Actual power on laadpaal: ' .. PowerLaadpaal, domoticz.LOG_DEBUG)
        domoticz.log('#4 Available energy: ' .. availableEnergy, domoticz.LOG_DEBUG)
        if domoticz.globalData.EVSE_CommunicationError ~= 'None' then
           domoticz.notify('There is an EVSE Communication Error', domoticz.PRIORITY_NORMAL)
        -- Determine the desired charging level
        local newLevel = 'Off'
                newLevel = level
        -- Check if EV is connected and switch is off
        if domoticz.globalData.EVSE_Connected == 'Connected' and EVSwitch_16A.state == 'Off' then
            local currentTime = os.time()
            if newLevel ~= domoticz.data.desiredLevel then
                domoticz.data.desiredLevel = newLevel
                domoticz.data.lastChangeTime = currentTime
            elseif currentTime - domoticz.data.lastChangeTime >= 120 then -- 2 minutes buffer
                if availableEnergy < 900 then
                    newLevel = 'Off'
                domoticz.devices('Charging Level').switchSelector(newLevel)
                domoticz.log('## Set to: ' .. newLevel, domoticz.LOG_DEBUG)
                -- Notification for starting or stopping charging
                local current_time = os.date('%Y-%m-%d %H:%M:%S')
                local subject, message
                if newLevel == 'Off' then
                    subject = 'We stopped charging on PV power!'
                    message = current_time .. '\nCharging level is set to: Off'
                    subject = 'We are charging on PV power!'
                    message = current_time .. '\nCharging level is set to: ' .. newLevel
                domoticz.notify(subject, message, domoticz.PRIORITY_NORMAL)
                domoticz.log('#8 Notification sent: ' .. subject, domoticz.LOG_DEBUG)
            domoticz.log('#10 Car charging on PV Power END of test loop', domoticz.LOG_DEBUG)
Switching is done using a selector switch and the 'EVSE Switch 16A' is used to be able to override PV power charging.
There is more to come.
I'll show you how to switch the SmartEVSE using mosquitto, how to set the charging level for the car using the Python Plugin: Volvo EV and a script that shows how much charging time and percentage is used for each charhing level.
Before publishing the scripts I'll consult CoPilot to enhance the scripts I wrote.
Re: SmartEVSE script for car charging
Posted: Saturday 26 October 2024 1:05
by Tukker
Here's the code for the Charging Level for the selector switch.
        devices = {'Charging Level'},
    logging = {
        -- Level can be domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG, domoticz.LOG_ERROR or domoticz.LOG_FORCE
        level = domoticz.LOG_DEBUG,
        marker = '---- Charging Level -----',
    execute = function(domoticz, triggerObject)
        local SunChargingLevel = domoticz.devices('Charging Level')
        local stateActions = {
            Off = {mode = 'Off', current = 0},
            ['6A'] = {mode = 'Normal', current = 60},
            ['8A'] = {mode = 'Normal', current = 80},
            ['10A'] = {mode = 'Normal', current = 100},
            ['13A'] = {mode = 'Normal', current = 130},
            ['16A'] = {mode = 'Normal', current = 160}
        local action = stateActions[SunChargingLevel.state]
        if action then
            domoticz.log(SunChargingLevel.state .. ' SunChargingLevel set to ' .. SunChargingLevel.state, domoticz.LOG_DEBUG)
            domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.104 -t "SmartEVSE/Set/Mode" -m ' .. action.mode)
            domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.104 -t "SmartEVSE/Set/CurrentOverride" -m ' .. action.current)
            domoticz.log('Unknown state: ' .. SunChargingLevel.state, domoticz.LOG_ERROR)
        domoticz.log('End Sun Charging Level set to: ' .. SunChargingLevel.state, domoticz.LOG_DEBUG)
As you can see this script uses Normal Mode, not Solar Mode or Smart Mode because Domoticz scripts govern the SmartEVSE.
The SmartEVSE as it is delivered has a Min of 6A and a max of 13A.
To change the max to 16A just set it in Solar mode, change the max and go back to Normal mode.
You can do it with the buttons on the device but you can do it just as easy by using curl or mosquitto commands from the RPI SSH command line.
The benefit of using mosquitto is that it is independent of the IP address of the SmartEVSE device.
The documentation on GitHub isn't perfect.
To set mode using mosquitto you need to use 0, 1, 2, 3 instead of the Curl Off, Normal, Solar, Smart
SmartEVSE with Volvo API feedback
Posted: Monday 28 October 2024 12:10
by Tukker
Here is the extended version which uses the information from the car and a new dimmer switch is added which sets the desired charging level.
The dimmer is 'XC40 battery charge set'
    on = {   --  at daytime','at 20 minutes after sunset
        timer = {'every 1 minutes', }, -- at daytime
    logging = {
        marker = 'Car charging Simple'
    data = {
        lastChangeTime = { initial = 0 },
        -- domoticz.devices('Charging Level').dump()
        local chargeLevelSet = domoticz.devices('XC40 battery charge set').level
	    local chargeLevelActual = domoticz.devices('XC40-ChargeLevel').nValue -- is een int en niet iets met een komma XC40-ChargeLevel
        local EVSE_Connected = domoticz.globalData.EVSE_Connected
            Off = 0,
            ['6A'] = 1400,
            ['8A'] = 1850,
            ['10A'] = 2300,
            ['13A'] = 3000,
            ['16A'] = 3700
        -- Get power data
        -- Logging
        -- Check if SmartEVSE is OK
           domoticz.notify('@1 There is an EVSE Communication Error', domoticz.PRIORITY_NORMAL)
           domoticz.devices('Auto laden').switchOff().forSec(30)
        local currentLevel = domoticz.devices('Charging Level').state
        domoticz.log('###### currentLevel : ' .. currentLevel, domoticz.LOG_DEBUG)
                newLevel = level
        domoticz.log('###### newLevel : ' .. newLevel, domoticz.LOG_DEBUG)
        -- Check if chargeLevelActual >= chargeLevelSet
        if chargeLevelActual >= chargeLevelSet and EVSE_Connected == 'Connected' then
            domoticz.devices('Charging Level').switchSelector('Off')
            domoticz.log('#5 Set to: ' .. newLevel, domoticz.LOG_DEBUG)
        -- Check if chargeLevelActual < chargeLevelSet
        elseif chargeLevelActual < chargeLevelSet and EVSE_Connected == 'Connected' and EVSwitch_16A.state == 'Off' then
            if availableEnergy < 900 then  -- 1400 - 500 = 900
                newLevel = 'Off'
            -- Notify charging state
            -- It sends the notification one time when the level has changed
            local current_time = os.date('%d-%m-%Y %H:%M')
            if newLevel == 'Off' and (currentLevel ~= newLevel) then
                subject = '@2 Charging on PV power has ended.'
                message = 'Charging Off, Energy : ' .. availableEnergy .. '\nTime : ' .. current_time
                if domoticz.LOG_DEBUG then
                    domoticz.log('#6 Notification sent: ' .. subject, domoticz.LOG_DEBUG)
            elseif newLevel ~= 'Off'and (currentLevel ~= newLevel) then
                subject = '@3 We are charging on PV power.'
                message = 'Charging ' .. newLevel .. ', Energy : ' .. availableEnergy .. '\nTime : ' .. current_time
                    domoticz.log('#7 Notification sent: ' .. subject, domoticz.LOG_DEBUG)
            domoticz.log('#7 Car charging on PV Power END of test loop', domoticz.LOG_DEBUG)
The code has many logging points.
Logging can be switched off by changing LOG_DEBUG to LOG_ERROR
To prevent being spammed by notifications a new notification is only being sent when a change in Charging Level occurs.
The code checks if the SmartEVSE has a Communication Error or None and switches off power to the SmartEVSE unit for 30 seconds to reset it.
Car charging Solar Simple for SmartEVSE
Posted: Tuesday 29 October 2024 15:07
by Tukker
Here's another to use the SmartEVSE device in Solar mode
-- Car charging Solar Simple for SmartEVSE
    on = { devices = {'Power'} },
    logging = {
        marker = 'Car Charging Solar',
        local function wattsToAmps(watts, volts)
            return watts / volts
        local amps = wattsToAmps(PowerReturn, 230)
        local current = amps * 10
           domoticz.notify('@1 There is an EVSE Communication Error, the device will restart in 30 seconds', domoticz.PRIORITY_NORMAL)
        if domoticz.devices('EVSE Switch 16A') == 'Off' and PowerReturn > 1400 then
            domoticz.executeShellCommand('mosquitto_pub  -h 192.168.2.104 -t "SmartEVSE/Set/Mode" -m Solar')
            domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.104 -t "SmartEVSE/Set/MainsMeter" -m ' .. current .. ':0:0')
        domoticz.log('#1 Energy return to the network: ' .. PowerReturn, domoticz.LOG_DEBUG)
        domoticz.log('#2 Power return in Ampère : ' .. amps, domoticz.LOG_DEBUG)
You may wonder why the earlier published codes are so complicated.
That's because I want to be able to log the time and % of charging for each state. (6A, 8A,10A,13A,16A)
Insight in charging levels and charging time
Posted: Sunday 03 November 2024 12:55
by Tukker
This script collects data from SmartEVSE charging level and charging time and displays time and relative percentage for each charging level in a Text Sensor (Charging Levels)
Charging levels.jpg (13.71 KiB) Viewed 5281 times
-- this script is for rendering insight in how much time PV powered charging is active
-- another script gathers these data at the end of each month to give a monthly oversight
-- time is calculated
-- relative percentages are calculated
-- at the end of the month data are cleared
-- at 23:56 daily data are collected and domoticz.data.solarkWhThisMonth updated
-- at 23:57 on the last day of each month the script Charging Time Monthly Summary Display
-- collects the data from the current month
-- at 23:58 on the last day of each month the data in this script are reset to zero to be able
-- to collect data for the next month in an empty table
    active = true,
        devices = { 'Charging Level' }, -- Charging Level is the name of the selector switch
        timer = {'at 23:56', 'at 23:58'}, -- { 'every minute' },
    data = {
        resetTrigger = { initial = 0 },
        startTime = { initial = 0 },
        totalTime = { initial = {0, 0, 0, 0, 0} },
        lastState = { initial = 0 },
        laadpaalkWhBeginThisMonth = { initial = 0 },
        laadpaalkWhThisMonth = { initial = 0 },
        solarkWhToday = { initial = 0 },
        solarkWhThisMonth = { initial = 0 },
    logging = {
        marker = '---- Charging Time Split Display -----',
local function padRight(label, value, length)
    local labelLength = #label
    local valueStr = tostring(value)
    local valueLength = #valueStr
    local padding = length - (labelLength + valueLength)
    return label .. string.rep('', padding) .. valueStr
        local selectorSwitch = domoticz.devices('Charging Level')
        local itemLevel = item and item.level or selectorSwitch.level
        if not itemLevel then
            domoticz.log('Error: item.level is nil', domoticz.LOG_ERROR)
            return
        -- Check if the reset trigger is activated
        -- domoticz.data.resetTrigger = 1
        -- if set to 1 all data will be reset to 0
        -- uncomment to reset
        -- the script ends after the reset.
        -- comment domoticz.data.resetTrigger = 1 again to let the script execute all the way
        domoticz.log('Time calculated with os.date({%H:%M})' .. os.date('%H:%M'), domoticz.LOG_DEBUG)
        domoticz.log('Calculated last day of '..os.date('%B')..' : ' .. (tostring(os.date('*t', os.time{year=os.date('%Y'), month=os.date('%m')+1, day=0}).day)), domoticz.LOG_DEBUG)
        -- and (os.date('%d') == tostring(os.date('*t', os.time{year=os.date('%Y'), month=os.date('%m')+1, day=0}).day)))  then
        if domoticz.data.resetTrigger == 1 or (os.date('%H:%M') == '23:58' and (os.date('%d') == tostring(os.date('*t', os.time{year=os.date('%Y'), month=os.date('%m')+1, day=0}).day)))  then
            domoticz.data.startTime = 0
            domoticz.data.totalTime = {0, 0, 0, 0, 0, 0}
            domoticz.data.lastState = 0
            domoticz.data.laadpaalkWhBeginThisMonth = 0
            domoticz.data.laadpaalkWhThisMonth = 0
            domoticz.data.times = {}
            domoticz.data.totalActiveTime = 0
            domoticz.data.percentages = {}
            domoticz.data.solarkWh = 0
            domoticz.data.solarkWhToday = 0
            domoticz.data.solarkWhThisMonth = 0
            domoticz.data.laadpaalkWhBeginThisMonth = domoticz.devices('Laadpaal').WhTotal/1000 or 0
            domoticz.log('Values reset to zero. Laadpaal start value set to: ' .. domoticz.data.laadpaalkWhBeginThisMonth, domoticz.LOG_INFO)
            -- Reset the trigger to 0
            domoticz.data.resetTrigger = 0
            return
        -- domoticz.data.laadpaalkWhThisMonth = 69.43 --domoticz.devices('Laadpaal').WhTotal/1000 -
        -- domoticz.data.solarkWhThisMonth = 6.83
        if domoticz.devices('EVSE Switch 16A').state == 'Off' then
            domoticz.log('#1 hier ' .. os.date('%H:%M'), domoticz.LOG_DEBUG)
            local now = os.time()
            local stateMap = {
                [0] = 1,  -- Off
                [10] = 2, -- 6A
                [20] = 3, -- 8A
                [30] = 4, -- 10A
                [40] = 5, -- 13A
                [50] = 6  -- 16A
            -- Add logging to check item.level
            domoticz.log('item.level: ' .. tostring(itemLevel), domoticz.LOG_DEBUG)
            local state = stateMap[itemLevel]
            domoticz.log('Current state: ' .. (state or 'unknown'), domoticz.LOG_INFO)
            if state == nil then
                domoticz.log('Error: state is nil for item.level: ' .. tostring(itemLevel), domoticz.LOG_ERROR)
                return
            if domoticz.data.lastState ~= 0 and domoticz.data.totalTime[domoticz.data.lastState] then
                local duration = now - domoticz.data.startTime
                domoticz.log('Duration for state ' .. domoticz.data.lastState .. ': ' .. duration .. ' seconds', domoticz.LOG_INFO)
                domoticz.data.totalTime[domoticz.data.lastState] = domoticz.data.totalTime[domoticz.data.lastState] + duration
            domoticz.data.startTime = now
            domoticz.data.lastState = state or 0
            -- Ensure totalTime values are not nil
            for i = 2, 6 do
                if domoticz.data.totalTime[i] == nil then
                    domoticz.data.totalTime[i] = 0
            -- Convert total time from seconds to truncated minutes
            local times = {
                padRight('6A: ', math.floor(domoticz.data.totalTime[2] / 60) .. 'm', 8),
                padRight('8A: ', math.floor(domoticz.data.totalTime[3] / 60) .. 'm', 8),
                padRight('10A: ', math.floor(domoticz.data.totalTime[4] / 60) .. 'm', 8),
                padRight('13A: ', math.floor(domoticz.data.totalTime[5] / 60) .. 'm', 8),
                padRight('16A: ', math.floor(domoticz.data.totalTime[6] / 60) .. 'm', 8)
            -- Calculate total active time excluding 'Off' state
            local totalActiveTime = 0
            for i = 2, 6 do
                totalActiveTime = totalActiveTime + domoticz.data.totalTime[i]
            -- Calculate percentage of time each state was active
           local percentages = {
               padRight('6A: ', string.format('%.0f', (domoticz.data.totalTime[2] / totalActiveTime) * 100) .. '%', 9),
               padRight('8A: ', string.format('%.0f', (domoticz.data.totalTime[3] / totalActiveTime) * 100) .. '%', 9),
               padRight('10A: ', string.format('%.0f', (domoticz.data.totalTime[4] / totalActiveTime) * 100) .. '%', 9),
               padRight('13A: ', string.format('%.0f', (domoticz.data.totalTime[5] / totalActiveTime) * 100) .. '%', 9),
               padRight('16A: ', string.format('%.0f', (domoticz.data.totalTime[6] / totalActiveTime) * 100) .. '%', 9)
            domoticz.log('#3 hier ' .. os.date('%H:%M'), domoticz.LOG_DEBUG)
            -- Get kWh from 'Laadpaal' meter
            domoticz.data.solarkWhToday = domoticz.devices('Laadpaal').WhToday / 1000
            domoticz.log('Collected solarkWhToday: ' .. domoticz.data.solarkWhToday .. ' kWh', domoticz.LOG_DEBUG)
            -- daily update of solarkWhThisMonth
            if os.date('%H:%M') == '23:56' then
                    domoticz.data.solarkWhThisMonth = domoticz.data.solarkWhThisMonth + domoticz.data.solarkWhToday
                    domoticz.log('Collected solarkWhToday: ' .. string.format('%.2f',domoticz.data.solarkWhToday) .. ' kWh', domoticz.LOG_DEBUG)
                    domoticz.log('Updated solarkWhThisMonth: ' .. string.format('%.2f',domoticz.data.solarkWhThisMonth) .. ' kWh', domoticz.LOG_DEBUG)
            -- Update the text sensor with the total active time for each state and kWh
            local textSensorDay = domoticz.devices('Charging Levels Day')
            if textSensorDay then
                local text = os.date('%B')..' : '..string.format('%.2f', domoticz.data.laadpaalkWhThisMonth)..' kWh, Solar : '.. string.format('%.2f',(domoticz.data.solarkWhThisMonth + domoticz.data.solarkWhToday)).. ' kWh\n  '..
                    '\nSolar Today : '..  string.format('%.2f',domoticz.data.solarkWhToday).. ' kWh\n\n  '
                textSensorDay.updateText(text)
                domoticz.log('Updated text sensor with: ' .. text, domoticz.LOG_INFO)
                domoticz.log('textSensorDay not found', domoticz.LOG_ERROR)
            local textSensor = domoticz.devices('Charging Levels')
            if textSensor then  -- '<pre style="font-family: monospace;font-size: 10px;">'..
                local text = os.date('%B %Y') .. '\n' ..
                table.concat(times, '|') .. '\n' ..
                table.concat(percentages, '|')   -- .. '</pre>'
                textSensor.updateText(text)
                domoticz.log('Text sensor not found', domoticz.LOG_ERROR)
        end -- if EVSE switch is off
The next script collects the data from the first script and presents a table in another Text Sensor (Charging Summary) where PV charging time and PV charging percentages are displayed for each month.
-- this script runs every day at 23:57
-- it only executes on the last day of the month
-- it collects the data
-- to reset all data change line 36
    active = true,
        timer = { 'at 23:57' }  -- {'every 1 minutes'} for testing
    data = {
        monthlyData = { initial = {} },
    logging = {
        marker = '---- Charging Time Monthly Summary Display -----',
    execute = function(domoticz)
        domoticz.log('os.date({%H:%M})' .. os.date('%H:%M'), domoticz.LOG_DEBUG)
        if (os.date('%d') == tostring(os.date('*t', os.time{year=os.date('%Y'), month=os.date('%m')+1, day=0}).day)) then
            local monthTextSensor = domoticz.devices('Charging Summary')
            local currentMonth = os.date('%m-%y')
            local text = textSensor.text
            -- Store the data for the current month
            domoticz.data.monthlyData[currentMonth] = text
            -- Keep only the last 12 months of data
            local keys = {}
            for k in pairs(domoticz.data.monthlyData) do
                table.insert(keys, k)
            table.sort(keys)
            while #keys > 12 do  -- > replacing 12 with 0 removes all data
                domoticz.data.monthlyData[keys[1]] = nil
                table.remove(keys, 1)
            -- Update the month text sensor with the collected data
            local monthText = ''
            for _, k in ipairs(keys) do
                monthText = monthText .. k .. ': ' .. domoticz.data.monthlyData[k] .. '\n\n'
            monthTextSensor.updateText(monthText)
            domoticz.log('Updated month text sensor with: ' .. monthText, domoticz.LOG_DEBUG)
Posted: Saturday 04 April 2026 0:15
by renerene
I recently updated my Alfen charging point to the latest firmware, 7.3.0-4377. Previously, I was able to control the charging current in Domoticz via the Alfen LAN plugin and the ‘Max Charge Current’ device.
However, with this new firmware, the charging station no longer works; the light flashes blue and the status remains stuck on ‘Load Balancing Forced Off’. Previously, I only got that status when I set Max Charge Current to zero.
Am I screwed with this firmware because load balancing is now a paid feature? How on earth do I get the charging station working again?...
