Virtual device attempt to concatenate a nil value (field 'v')  [Solved]
hemant5400z
Post by hemant5400z »
Hi All,
I have a virtual device which keeps track of my monthly total usage (general managed counter) idx 204.
All of a sudden my script stopped working with the following error:
2024-10-25 10:17:11.025 Error: dzVents: An error occurred when calling event handler MaandVerbruik
2024-10-25 10:17:11.025 Error: dzVents: ...data/scripts/dzVents/generated_scripts/MaandVerbruik.lua:36: attempt to concatenate a nil value (field 'v')
bleow the script:
local httpResponses = "monthTotalVerbruik"
timer = { "every hour" },
--devices = {64},
httpResponses = { httpResponses .. "*" }
execute = function(dz, item)
-- ****************************** Your settings below this line ***************************************************
usageDevice = dz.devices(64) -- Replace xxxx with ID of energyDevice you want to track
monthTotal = dz.devices(204) -- Create as virtual managed counter (energy) and change yyyy to the ID of the new device
-- ****************************** No changes required below this line *********************************************
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
local function triggerJSON(id, period, delay)
local delay = delay or 0
local URLString = "http://192.168.1.7:8080/json.htm?type=g ... ter&range=" ..
period .. "&idx=" .. id
dz.openURL({ url = URLString,
method = "GET",
callback = httpResponses .. "_" .. period}).afterSec(delay)
local function calculateMonthTotal(rt)
local monthTotal = 0
local currentMonth = dz.time.rawDate:sub(1,7)
for id, result in ipairs(rt) do
if rt[id].d:sub(1,7) == currentMonth then
logWrite(rt[id].d .. " ==>> " .. rt[id].v)
monthTotal = monthTotal + rt[id].v + rt[id].v2
return monthTotal * 1000
if not item.isHTTPResponse then
triggerJSON(usageDevice.id, "month")
elseif item.ok then -- statusCode == 2xx
monthTotal.update(0,calculateMonthTotal(item.json.result))
logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")" ,dz.LOG_ERROR)
logWrite(item.data)
I cannot determine what is wrong and why it all of a sudden keeps giving me this error as of Yesterday, all the help appreciated.
Thanks,
Hemant
Kedi
Re: Virtual device attempt to concatenate a nil value (field 'v')  [Solved]
Post by Kedi »
I think that in an other thread it was mentioned that the '.v' should be '.v1' now.
Try that.
hemant5400z
i just changed:
into:
logWrite(rt[id].d .. " ==>> " .. rt[id].v1)
monthTotal = monthTotal + rt[id].v1 + rt[id].v2
Does anyone know when this was changed? looks like something recently.
Hemant
hemant5400z
however my docker version is from deceber 2023 (beta), so there was no update on the docker container.
Hemant
HvdW
Domoticz version: 2023.2
Post by HvdW »
You can clarify the response with this code:
        if (item.isTimer) then
            domoticz.openURL({
            -- url = "http://152.53.105.165/api/json whatever
            method = 'GET',
            callback = 'WeerLiveDataRetrieved'
        elseif (item.isHTTPResponse) then
            if (item.ok) then -- statusCode == 2xx
                -- Display all data from weerlive with the domoticz.utils.dumpTable(item.json) statement
                -- domoticz.log(domoticz.utils.dumpTable(item.json),domoticz.LOG_DEBUG)
Bugs bug me.
Domoticz version: 2024.7
hemant5400z wrote: Friday 25 October 2024 10:53 Hi,
i just changed:
into:
Hemant
This was changed in one of the latest release for supporting cost calculation on P1 devices so it seems you have updated your docker system recently. Check menu setup - About what Domoticz version you are running
hemant5400z
Thanks,
It is all working again so issue is solved
