Not sure if it is a Domoticz issue, but since yesterday my T6 thermostat shows a -18 deg temperature outdoors.
Setting the target temperature to 20 on the thermostat directly for the room is correctly displayed in Domoticz. I notice errors in the log for reaching the T6 thermostat in Domoticz, but not constantly. As it is reflecting the manually set setpoint think the communication by time is working.
Is it a honeywell central issue?
PS: The resideo (honeywell) app is showing same setpoint but also showing more accurate outdoor temperatures.
Noticed that the app was on geofencing. Switching it off, it started to show the actual outdoor temperature in domoticz.
Solved: Honeywell T6 shows -18 temperature
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
