Weather forecast
Dave47
Domoticz version: 2023.1
Weather forecast
Post by Dave47 »
How can we setup KNMI weather in Dashticz
We have a API -key
I made in Dasthicz this block
 blocks['weather'] = {
  type: 'weather',
  apikey: 'our key', //Your API key
  city: 'Amsterdam',
Nothing shows in Dashticz.
What is wrong?
Must we setup KNMI in Domoticz first?
If yes, there is nothning for KNMI in the hardware setup
HansieNL
Re: Weather forecast
Post by HansieNL »
Can you add the following code to your block and see if that works for you
  provider: 'knmi',
Blah blah blah
Dave47
Post by Dave47 »
    provider: 'knmi',
It doesnt work.
I have no setup in Domoticz for knmi
Do i need that also?
HansieNL
Post by HansieNL »
KNMI block will work without Domoticz settings.
I just tried with my API and got a weather forecast, so there must still be something wrong.
I would suggest to create a minimal CONFIG.js to test.
Blah blah blah
Dave47
Post by Dave47 »
Ok. I will try that
HansieNL
Post by HansieNL »
Before you can use the weather module, you must request an API key at: https://weerlive.nl/api/toegang/index.php
Like I told before I tried with minimal CONFIG.js:
var config = {}
config['domoticz_ip'] = 'http://192.168.1.123:8123'; // change to your own IP-address and port
config['app_title'] = 'Dashticz V3';
var blocks = {}
  type: 'weather',
  provider: 'knmi',
  apikey: 'apikey1234', // change to your own Weerlive API-key
  city: 'Amsterdam',
  count: 3
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['weather']
columns[1]['width'] = 5;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
screens[1]['columns'] = [1]
Blah blah blah
Dave47
Post by Dave47 »
I tried that but is not working.
When i do the url in the browser it works with that API
Dave47
Post by Dave47 »
We have a beta dashticz version.
Is that the problem?
HansieNL
Post by HansieNL »
Should be no problem. You have latest beta? If not, can you try with latest beta and see if it then works.
You can copy my minimal CONFIG.js and just change IP and Key and that should normally work.
Be sure there is no custom.js or custom.css, because that may affect the working of CONFIG.js
Blah blah blah
