Domoticz crash
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Biarritz
Domoticz crash
Post by Biarritz »
Hi For some time now Domoticz is crashing on my Pi 4, causing also pihole and Mosquito MQTT to stop.
Version: 2024.7
Build Hash: b317cfab1
Compile Date: 2024-07-13 16:59:31
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Aug 26 2024, 07:20:54) [GCC 12.2.0]
I use an SSD
Included is the domoticz_crash.log. Using this information I cannot find any information on what is causing the crash. Perhaps somebody can help?
GNU nano 7.2 domoticz_crash.log
[New LWP 13335]
[New LWP 13336]
[New LWP 13337]
[New LWP 13338]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
0x0000007fb93882a4 in __GI___wait4 (pid=13339, stat_loc=0x7fdea10e04, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
30      ../sysdeps/unix/sysv/linux/wait4.c: No such file or directory.
  Id   Target Id                                    Frame
* 1    Thread 0x7fb99b3040 (LWP 13334) "domoticz"   0x0000007fb93882a4 in __GI___wait4 (pid=13339, stat_loc=0x7fdea10e04, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
  2    Thread 0x7fb794ef00 (LWP 13335) "SQLHelper"  syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
  3    Thread 0x7fb713ef00 (LWP 13336) "PluginMgr"  syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
  4    Thread 0x7fb63e3f00 (LWP 13337) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
  5    Thread 0x7fb5bd3f00 (LWP 13338) "MQTTPush"   syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
Thread 5 (Thread 0x7fb5bd3f00 (LWP 13338) "MQTTPush"):
#0  syscall () at ../sysdeps/unix/sysv/linux/aarch64/syscall.S:38
#1  0x00000055594ddef0 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
#2  0x0000005558f1c70c in CMQTTPush::Do_Work() ()
#3  0x00000055594dbc0c in execute_native_thread_routine ()
#4  0x0000007fb934ee30 in start_thread (arg=0x7fdea11da7) at ./nptl/pthread_create.c:442
#5  0x0000007fb93b7adc in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:79
Thread 4 (Thread 0x7fb63e3f00 (LWP 13337) "InfluxPush"):
#2  0x0000005558f17614 in CInfluxPush::Do_Work() ()
Thread 3 (Thread 0x7fb713ef00 (LWP 13336) "PluginMgr"):
#2  0x000000555923d07c in Plugins::CPluginSystem::Do_Work() ()
#4  0x0000007fb934ee30 in start_thread (arg=0x7fdea11b47) at ./nptl/pthread_create.c:442
Thread 2 (Thread 0x7fb794ef00 (LWP 13335) "SQLHelper"):
#2  0x0000005558e4400c in CSQLHelper::Do_Work() ()
#4  0x0000007fb934ee30 in start_thread (arg=0x7fdea0e287) at ./nptl/pthread_create.c:442
Thread 1 (Thread 0x7fb99b3040 (LWP 13334) "domoticz"):
#0  0x0000007fb93882a4 in __GI___wait4 (pid=13339, stat_loc=0x7fdea10e04, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
#1  0x0000005558e2c800 in dumpstack_gdb(bool) ()
#2  0x0000005558e2cdbc in signal_handler(int, siginfo_t*, void*) ()
#3  <signal handler called>
#4  __pthread_kill_implementation (threadid=548574801984, signo=signo@entry=6, no_tid=no_tid@entry=0) at ./nptl/pthread_kill.c:44
#5  0x0000007fb9350a44 in __pthread_kill_internal (signo=6, threadid=<optimized out>) at ./nptl/pthread_kill.c:78
#6  0x0000007fb930a72c in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
#7  0x0000007fb92f747c in __GI_abort () at ./stdlib/abort.c:79
#8  0x00000055594e2510 in __gnu_cxx::__verbose_terminate_handler() ()
#9  0x0000005559461434 in __cxxabiv1::__terminate(void (*)()) ()
#10 0x0000005559461480 in std::terminate() ()
#11 0x0000005558da8088 in std::_Sp_counted_ptr_inplace<std::thread, std::allocator<std::thread>, (__gnu_cxx::_Lock_policy)2>::_M_dispose() ()
#12 0x0000005558da99d4 in std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release() ()
#13 0x0000005558e06f20 in CMQTTPush::~CMQTTPush() ()
#14 0x0000007fb930ce8c in __run_exit_handlers (status=1, listp=0x7fb9470710 <__exit_funcs>, run_list_atexit=run_list_atexit@entry=true, run_dtors=run_dtors@entry=true) at ./stdlib/exit.c:116
#15 0x0000007fb930cf60 in __GI_exit (status=<optimized out>) at ./stdlib/exit.c:146
#16 0x0000007fb92f7744 in __libc_start_call_main (main=main@entry=0x5558d42cf8 <main>, argc=argc@entry=5, argv=argv@entry=0x7fdea128d8) at ../sysdeps/nptl/libc_start_call_main.h:74
#17 0x0000007fb92f7818 in __libc_start_main_impl (main=0x5558d42cf8 <main>, argc=5, argv=0x7fdea128d8, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=<optimized out>) at ../csu/libc-start.c:360
#18 0x0000005558d6b480 in _start ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Main thread:
[Inferior 1 (process 13334) detached]
