After changing hardware and devices values end up all in the same day
Posted: Friday 11 October 2024 16:25
by DJathome
Forgive me for still being in the 'newbie' state.
After changing a few things in my setup (trying to a a second SMA inverter) the production daily values of the original one ended up all accumulated in one day as if al production was done in that date.
Result is that I see between 20 and 30 MEGAWatthours of production on, in my case, passed 4th of October.
Now to be honest I have some recollection of a similar problem being reasonably simply corrected somewhere here but it seems I am using the wrong keywords to search as after some hours browsing I did not find a post on the subject yet.
As you might see in the attached screenshot all my production from the past years months and days end up on that 4th October.
Re: After changing hardware and devices values end up all in the same day
Posted: Friday 11 October 2024 19:30
Attachment are currently not working on the forum.
But you probably can delete that huge spike from the graph and database by clicking on the value with shift button pressed. A popup will be shown to confirm the deletion of that incorrect value.
Posted: Friday 11 October 2024 20:42
by DJathome
Ok thanks for a swift reply, does this also restore the values to their dates in the past?
Posted: Friday 11 October 2024 22:53
No, but probably the values are there but you do not see them due to the huge difference. But better check with a csv/excel export that you can do from the graph (check the hamburger menu in the graph)
Posted: Saturday 12 October 2024 8:58
by FlyingDomotic
The "issue" you had is something common, happening when a cumulative counter goes back to zero (is reset) externally. Is probably occurred when you installed your second SMA inverter.
Using "shift click" method, you'll only loose the 4 October production. If you have a way to known/estimate it, it's possible to "force" it in database (at your own risks).
