security dz website/wiki since hack
BartSr
Domoticz version: V2024.7
Post by BartSr »
recently dz website as well as wiki was hacked so we couldnot login.
Te prevent this owner Gizmocus added a security thing which keeps hackers out.
But. I use raspberry pi for running dz and all what belongs to it as docker wireguard etc.
Once I do a fresh install I used to follow instructions from internet. Copy and past was normal. But with this new security the pi's browser keeps looking wether it's safe to startup the browser. Is there a workaround?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2024.7
Re: security dz website/wiki since hack
If you open a browser and go to the forum or wiki you get a human security check. There is no workaround.
For me it mostly just continues without me having to do anything. Sometimes I have to click to confirm I am human (there are others also doubting about that :) ).
Egregius
Domoticz version: v2024.7
Post by Egregius »
I find it quite annoying to have to wait a few seconds for the forum to open. Because of this I come less online here.
BartSr
Post by BartSr »
my problem with raspberry pi is that I cannot use anylonger a webbrowser
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr wrote: Friday 11 October 2024 14:41 my problem with raspberry pi is that I cannot use anylonger a webbrowser
You also cannot go to another website like google.com? Because then something else is the issue on your system. You then have to check your network and/or router/firewall settings.
Edit: Perhaps it is this? https://forums.raspberrypi.com/viewtopic.php?t=358637
gizmocuz
Post by gizmocuz »
Are you using a VPN? That could also be the issue.
This method from Cloudflare is quite commonly used.
I will probably remove it someday, but let's keep those script kiddies annoyed for some time more
BartSr
Post by BartSr »
Gizmocus no, I used a pi with fresh new debian image. It's in my home. Not possible to open domoticz.com nor the wiki.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
But if you do not answer my questions it will be hard to determine what's is going on ..
BartSr
Post by BartSr »
@walter
sorry, forgot to mention it's a pi 3+.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
