Touch base: options for Bosch Easycontrol CT200?
Posted: Monday 30 September 2024 14:30
Hi Forum,
I'm looking for a practical way to add the Bosch Easycontrol CT200 thermostat to Domoticz. I previsously had the Nefit Easy CT100 up & running, objective is to get something similar for the CT200.
I noted a plugin https://github.com/ggraat/domoticz-easycontrol-plugin which uses the Bosch-XMPP code https://github.com/robertklep/bosch-xmpp. This looks very promising!
Could someone share some experience/guidance/steps to install this on an RPI?
Update: For experimenting purposes, I installed bosch-xmpp on a Windows system. With CLI commands, I was able to obtain data via the Bosch system originating from my CT200 Easycontrol. Also, when setting bosch-xmpp in 'bridge' mode, I could issue http requests, like those created by the plugin, using Postman to Localhost. It is likely I can get to the same level on a RPI as well. So, it seems all elements are there to get the CT200 Easycontrol up&running in Domoticz.
However, due to my limited knowledge, I'm confused about how for example to ensure CT200 login credentials are practically handled and how to ensure that the bosch-xmpp code is started in 'bridge mode' each time the RPI is booted.
In case someone has this setup in use, I would appreciate additional detail on how it was setup.
