Occasional Crash with MQTT
Posted: Tuesday 17 September 2024 9:36
Hello everybody,
I have a problem with my configuration, and I tried for weeks to solve it but I just do not see the solution.
The situation:
On some point (after days, weeks), my domoticz restarts. This happened running domoticz in docker, and also under a new installation.
My domoticz runs under proxmox, at the moment with ubuntu 24. My zigbees run in an lxc, mqtt as well. The mqtt-IP is 192.168.1.62. Domoticz version is the newest (see logs below).
I moved to ubuntu to see the logs, since I just could not find them in docker after the restart of domoticz.
If someone needs another log level, or other information, please let me know. I'm not a linux expert, I just want domoticz to run smoothly
In my logs, I can see:
First, domoticz reconnects to the mqtt feeds:
After that, it begins to discover some devices:
And directly after that:
Now it still discovers some devices, but about one second later:
now agains some discoveries, and then:
I made a notification on domoticz restart via telegram. Shortly after domoticz restarts:
The whole sequence (perhaps easier to search?):
Thanks very much in advance!
Jens
The situation:
2024-09-17 06:59:37.856 Status: zigbee2mqtt: Connecting to 192.168.1.62:1883
2024-09-17 06:59:37.856 Status: zigbee2mqttkabel: Connecting to 192.168.1.62:1883
2024-09-17 06:59:37.857 Status: zwave2mqtt: Connecting to 192.168.1.62:1883
2024-09-17 06:59:37.857 Status: tgtg: Connecting to 192.168.1.62:1883
2024-09-17 06:59:38.057 Status: zigbee2mqttkabel: Connected to: 192.168.1.62:1883
2024-09-17 06:59:38.057 Status: zwave2mqtt: Connected to: 192.168.1.62:1883
2024-09-17 06:59:38.058 Status: zigbee2mqtt: Connected to: 192.168.1.62:1883
2024-09-17 06:59:38.058 Status: tgtg: Connected to: 192.168.1.62:1883
2024-09-17 06:59:38.459 Status: zigbee2mqttkabel: Discovered: Zigbee2MQTT Bridge (Restart required)/Zigbee2MQTT Bridge (Restart required) (unique_id: bridge_0x4c5bb3fffe930bb8_restart_required_zigbee2mqttkabel)
2024-09-17 06:59:38.461 Status: zigbee2mqtt: Discovered: Zigbee2MQTT Bridge (Restart required)/Zigbee2MQTT Bridge (Restart required) (unique_id: bridge_0xe0798dfffe8d911f_restart_required_zigbee2mqtt)
2024-09-17 06:59:38.561 Status: zigbee2mqtt: Discovered: Spielzimmer - Fensterlinks/Spielzimmer - Fensterlinks (unique_id: 0x00158d0002c39449_contact_zigbee2mqtt)
2024-09-17 06:59:38.663 Status: zigbee2mqtt: Discovered: Spielzimmer - Fenstermitte/Spielzimmer - Fenstermitte (unique_id: 0x00158d0002c9e6c7_contact_zigbee2mqtt)
2024-09-17 06:59:38.764 Status: zigbee2mqtt: Discovered: Spielzimmer - Fensterrechts/Spielzimmer - Fensterrechts (unique_id: 0x00158d0002bfede4_contact_zigbee2mqtt)
2024-09-17 06:59:38.777 Status: zwave2mqtt: Discovered: nodeID_12 (nodeID_12_any)/nodeID_12 (nodeID_12_any) (unique_id: zwavejs2mqtt_0xeae3576a_12-48-0-Any)
2024-09-17 06:59:38.855 Status: Closing application!...
2024-09-17 06:59:38.855 Status: Stopping worker...
2024-09-17 06:59:38.868 Status: zigbee2mqttkabel: Discovered: Küchekaffee Bewe/Küchekaffee Bewe (unique_id: 0x00158d00026e09a9_occupancy_zigbee2mqttkabel)
2024-09-17 06:59:38.877 Status: zwave2mqtt: Discovered: nodeID_12 (nodeID_12_temperature_air)/nodeID_12 (nodeID_12_temperature_air) (unique_id: zwavejs2mqtt_0xeae3576a_12-49-0-Air_temperature)
2024-09-17 06:59:38.960 Status: RxQueue: queue worker stopped...
2024-09-17 06:59:39.961 Status: WebServer(SSL) stopped
2024-09-17 06:59:39.962 Status: TCPServer: shared server stopped
2024-09-17 06:59:39.962 Status: Stopping all hardware...
2024-09-17 06:59:41.858 Status: Ping: Worker stopped...
2024-09-17 06:59:41.859 Status: zwave2mqtt: Worker stopped...
2024-09-17 06:59:41.870 Status: zigbee2mqtt: Worker stopped...
2024-09-17 06:59:41.881 Status: tgtg: Worker stopped...
2024-09-17 06:59:41.882 Status: zigbee2mqttkabel: Discovered: wohnzimmer multisensor/wohnzimmer multisensor (unique_id: 0x00158d0002b60a7d_device_temperature_zigbee2mqttkabel)
2024-09-17 06:59:41.892 Status: zigbee2mqttkabel: Worker stopped...
2024-09-17 06:59:41.903 Status: Scheduler stopped...
2024-09-17 06:59:41.903 Status: EventSystem: Stopped...
2024-09-17 07:00:08.200 Status: Domoticz V2024.7 (c)2012-2024 GizMoCuz
2024-09-17 07:00:08.200 Status: Build Hash: b317cfab1, Date: 2024-07-13 16:59:31
2024-09-17 07:00:08.200 Status: Startup Path: /home/domoticz/
2024-09-17 07:00:08.245 Sunrise: 07:10:00 SunSet: 19:38:00
2024-09-17 07:00:08.245 Day length: 12:28:00 Sun at south: 13:24:00
2024-09-17 07:00:08.245 Civil twilight start: 06:38:00 Civil twilight end: 20:09:00
2024-09-17 07:00:08.245 Nautical twilight start: 06:01:00 Nautical twilight end: 20:46:00
2024-09-17 07:00:08.245 Astronomical twilight start: 05:22:00 Astronomical twilight end: 21:25:00
2024-09-17 07:00:08.277 Status: PluginSystem: Started, Python version '3.12.3', 1 plugin definitions loaded.
2024-09-17 07:00:08.280 Active notification Subsystems: email, http, telegram (3/13)
2024-09-17 07:00:08.281 Status: WebServer(HTTP) started on address: :: with port 8080
2024-09-17 07:00:08.286 Status: WebServer(SSL) started on address: :: with port 443
2024-09-17 07:00:08.288 Starting shared server on: :::6144
2024-09-17 07:00:08.288 Status: TCPServer: shared server started...
2024-09-17 07:00:08.288 Status: RxQueue: queue worker started...
2024-09-17 07:00:10.289 Status: EventSystem: reset all events...
2024-09-17 07:00:10.290 Status: Ping: Worker started...
2024-09-17 07:00:10.290 Status: NotificationSystem: thread started...
2024-09-17 06:59:38.968 Status: zigbee2mqttkabel: Discovered: wohnzimmer multisensor/wohnzimmer multisensor (unique_id: 0x00158d0002b60a7d_occupancy_zigbee2mqttkabel)
2024-09-17 06:59:38.978 Status: zwave2mqtt: Discovered: nodeID_12 (nodeID_12_illuminance)/nodeID_12 (nodeID_12_illuminance) (unique_id: zwavejs2mqtt_0xeae3576a_12-49-0-Illuminance)
2024-09-17 06:59:39.069 Status: zigbee2mqttkabel: Discovered: esszimmer sensor/esszimmer sensor (unique_id: 0x00158d0002b72add_occupancy_zigbee2mqttkabel)
2024-09-17 06:59:39.078 Status: zwave2mqtt: Discovered: nodeID_12 (nodeID_12_battery_level)/nodeID_12 (nodeID_12_battery_level) (unique_id: zwavejs2mqtt_0xeae3576a_12-128-0-level)
2024-09-17 06:59:39.170 Status: zigbee2mqttkabel: Discovered: flurtreppe oben/flurtreppe oben (unique_id: 0x00158d00030519b6_occupancy_zigbee2mqttkabel)
2024-09-17 06:59:39.170 Status: zigbee2mqtt: Discovered: FlurUnten - Küche/FlurUnten - Küche (unique_id: 0x00158d000313cfcc_occupancy_zigbee2mqtt)
2024-09-17 06:59:39.179 Status: zwave2mqtt: Discovered: nodeID_12 (nodeID_12_battery_islow)/nodeID_12 (nodeID_12_battery_islow) (unique_id: zwavejs2mqtt_0xeae3576a_12-128-0-isLow)
2024-09-17 06:59:39.270 Status: zigbee2mqttkabel: Discovered: FlurUnten Tuer/FlurUnten Tuer (unique_id: 0x00158d00032c2a52_occupancy_zigbee2mqttkabel)
2024-09-17 06:59:39.271 Status: zigbee2mqtt: Discovered: Badezimmer fenster/Badezimmer fenster (unique_id: 0x00158d0002536d35_contact_zigbee2mqtt)
2024-09-17 06:59:39.280 Status: zwave2mqtt: Discovered: nodeID_12 (nodeID_12_event_general_purpose)/nodeID_12 (nodeID_12_event_general_purpose) (unique_id: zwavejs2mqtt_0xeae3576a_12-156-0-state-0)
2024-09-17 06:59:39.371 Status: zigbee2mqttkabel: Discovered: Kueche Tuer/Kueche Tuer (unique_id: 0x00158d0002c9e51f_contact_zigbee2mqttkabel)
2024-09-17 06:59:39.371 Status: zigbee2mqtt: Discovered: Badezimmer wasser/Badezimmer wasser (unique_id: 0x00158d000271b049_water_leak_zigbee2mqtt)
2024-09-17 06:59:39.380 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_any)/nodeID_13 (nodeID_13_any) (unique_id: zwavejs2mqtt_0xeae3576a_13-48-0-Any)
2024-09-17 06:59:39.461 Status: WebServer(HTTP) stopped
2024-09-17 06:59:39.472 Status: zigbee2mqtt: Discovered: Badezimmer wasser/Badezimmer wasser (unique_id: 0x00158d000271b049_battery_low_zigbee2mqtt)
2024-09-17 06:59:39.481 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_temperature_air)/nodeID_13 (nodeID_13_temperature_air) (unique_id: zwavejs2mqtt_0xeae3576a_13-49-0-Air_temperature)
2024-09-17 06:59:39.572 Status: zigbee2mqttkabel: Discovered: Buero - Bewegung/Buero - Bewegung (unique_id: 0x00158d00025f2437_occupancy_zigbee2mqttkabel)
2024-09-17 06:59:39.573 Status: zigbee2mqtt: Discovered: Esszimmer Fenster links/Esszimmer Fenster links (unique_id: 0x00158d0002c0d0a2_contact_zigbee2mqtt)
2024-09-17 06:59:39.581 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_illuminance)/nodeID_13 (nodeID_13_illuminance) (unique_id: zwavejs2mqtt_0xeae3576a_13-49-0-Illuminance)
2024-09-17 06:59:39.673 Status: zigbee2mqtt: Discovered: Esszimmer Fenster rechts /Esszimmer Fenster rechts (unique_id: 0x00158d0002c0e307_contact_zigbee2mqtt)
2024-09-17 06:59:39.682 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_generic_general_purpose)/nodeID_13 (nodeID_13_generic_general_purpose) (unique_id: zwavejs2mqtt_0xeae3576a_13-49-0-General_purpose)
2024-09-17 06:59:39.774 Status: zigbee2mqtt: Discovered: Haustür /Haustür (unique_id: 0x00158d0002c78d12_contact_zigbee2mqtt)
2024-09-17 06:59:39.782 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_battery_level)/nodeID_13 (nodeID_13_battery_level) (unique_id: zwavejs2mqtt_0xeae3576a_13-128-0-level)
2024-09-17 06:59:39.874 Status: zigbee2mqtt: Discovered: Kinderzimmer Fenster /Kinderzimmer Fenster (unique_id: 0x00158d00024e50de_contact_zigbee2mqtt)
2024-09-17 06:59:39.883 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_battery_islow)/nodeID_13 (nodeID_13_battery_islow) (unique_id: zwavejs2mqtt_0xeae3576a_13-128-0-isLow)
2024-09-17 06:59:39.975 Status: zigbee2mqtt: Discovered: Büro /Büro (unique_id: 0x00158d000251eaf1_contact_zigbee2mqtt)
2024-09-17 06:59:39.984 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_event_general_purpose)/nodeID_13 (nodeID_13_event_general_purpose) (unique_id: zwavejs2mqtt_0xeae3576a_13-156-0-state-0)
2024-09-17 06:59:40.074 Status: zigbee2mqttkabel: Discovered: Zigbee2MQTT Bridge (Version)/Zigbee2MQTT Bridge (Version) (unique_id: bridge_0x4c5bb3fffe930bb8_version_zigbee2mqttkabel)
2024-09-17 06:59:40.084 Status: zwave2mqtt: Discovered: nodeID_13 (nodeID_13_dimmer)/nodeID_13 (nodeID_13_dimmer) (unique_id: zwavejs2mqtt_0xeae3576a_13-38-0-currentValue)
2024-09-17 06:59:40.174 Status: zigbee2mqttkabel: Discovered: Zigbee2MQTT Bridge (Coordinator version)/Zigbee2MQTT Bridge (Coordinator version) (unique_id: bridge_0x4c5bb3fffe930bb8_coordinator_version_zigbee2mqttkabel)
2024-09-17 06:59:40.176 Status: zigbee2mqtt: Discovered: Garage offen/Garage offen (unique_id: 0x00158d000309c26e_contact_zigbee2mqtt)
2024-09-17 06:59:40.185 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_any)/nodeID_14 (nodeID_14_any) (unique_id: zwavejs2mqtt_0xeae3576a_14-48-0-Any)
2024-09-17 06:59:40.275 Status: zigbee2mqttkabel: Discovered: Zigbee2MQTT Bridge (Network map)/Zigbee2MQTT Bridge (Network map) (unique_id: bridge_0x4c5bb3fffe930bb8_network_map_zigbee2mqttkabel)
2024-09-17 06:59:40.276 Status: zigbee2mqtt: Discovered: Garage zu /Garage zu (unique_id: 0x00158d000309c265_contact_zigbee2mqtt)
2024-09-17 06:59:40.286 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_temperature_air)/nodeID_14 (nodeID_14_temperature_air) (unique_id: zwavejs2mqtt_0xeae3576a_14-49-0-Air_temperature)
2024-09-17 06:59:40.386 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_illuminance)/nodeID_14 (nodeID_14_illuminance) (unique_id: zwavejs2mqtt_0xeae3576a_14-49-0-Illuminance)
2024-09-17 06:59:40.476 Status: zigbee2mqttkabel: Discovered: Zigbee2MQTT Bridge (Permit join timeout)/Zigbee2MQTT Bridge (Permit join timeout) (unique_id: bridge_0x4c5bb3fffe930bb8_permit_join_timeout_zigbee2mqttkabel)
2024-09-17 06:59:40.477 Status: zigbee2mqtt: Discovered: Schlafzimmer fenster/Schlafzimmer fenster (unique_id: 0x00158d0002b52ec9_contact_zigbee2mqtt)
2024-09-17 06:59:40.487 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_battery_level)/nodeID_14 (nodeID_14_battery_level) (unique_id: zwavejs2mqtt_0xeae3576a_14-128-0-level)
2024-09-17 06:59:40.587 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_battery_islow)/nodeID_14 (nodeID_14_battery_islow) (unique_id: zwavejs2mqtt_0xeae3576a_14-128-0-isLow)
2024-09-17 06:59:40.688 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_event_general_purpose)/nodeID_14 (nodeID_14_event_general_purpose) (unique_id: zwavejs2mqtt_0xeae3576a_14-156-0-state-0)
2024-09-17 06:59:40.778 Status: zigbee2mqtt: Discovered: Außen Bewässerung (Frost lock)/Außen Bewässerung (Frost lock) (unique_id: 0x847127fffed07c66_frost_lock_zigbee2mqtt)
2024-09-17 06:59:40.789 Status: zwave2mqtt: Discovered: nodeID_14 (nodeID_14_dimmer)/nodeID_14 (nodeID_14_dimmer) (unique_id: zwavejs2mqtt_0xeae3576a_14-38-0-currentValue)
2024-09-17 06:59:40.889 Status: zwave2mqtt: Discovered: Grill (Grill_switch)/Grill (Grill_switch) (unique_id: zwavejs2mqtt_0xeae3576a_18-37-0-currentValue)
2024-09-17 06:59:40.990 Status: zwave2mqtt: Discovered: Grill (Grill_electric_kwh_value)/Grill (Grill_electric_kwh_value) (unique_id: zwavejs2mqtt_0xeae3576a_18-50-0-value-65537)
2024-09-17 06:59:41.091 Status: zwave2mqtt: Discovered: Grill (Grill_electric_w_value)/Grill (Grill_electric_w_value) (unique_id: zwavejs2mqtt_0xeae3576a_18-50-0-value-66049)
2024-09-17 06:59:41.180 Status: zigbee2mqtt: Discovered: Außen Bewässerung (Reset frost lock)/Außen Bewässerung (Reset frost lock) (unique_id: 0x847127fffed07c66_reset_frost_lock_zigbee2mqtt)
2024-09-17 06:59:41.292 Status: zwave2mqtt: Discovered: nodeID_34 (nodeID_34_any)/nodeID_34 (nodeID_34_any) (unique_id: zwavejs2mqtt_0xeae3576a_34-48-0-Any)
2024-09-17 06:59:41.379 Status: zigbee2mqttkabel: Discovered: Küchekaffee Bewe/Küchekaffee Bewe (unique_id: 0x00158d00026e09a9_battery_zigbee2mqttkabel)
2024-09-17 06:59:41.381 Status: zigbee2mqtt: Discovered: Küche - kaffeelicht (Effect)/Küche - kaffeelicht (Effect) (unique_id: 0x5c0272fffe86df31_effect_zigbee2mqtt)
2024-09-17 06:59:41.392 Status: zwave2mqtt: Discovered: nodeID_34 (nodeID_34_temperature_air)/nodeID_34 (nodeID_34_temperature_air) (unique_id: zwavejs2mqtt_0xeae3576a_34-49-0-Air_temperature)
2024-09-17 06:59:41.480 Status: zigbee2mqttkabel: Discovered: Küchekaffee Bewe/Küchekaffee Bewe (unique_id: 0x00158d00026e09a9_voltage_zigbee2mqttkabel)
2024-09-17 06:59:41.493 Status: zwave2mqtt: Discovered: nodeID_34 (nodeID_34_illuminance)/nodeID_34 (nodeID_34_illuminance) (unique_id: zwavejs2mqtt_0xeae3576a_34-49-0-Illuminance)
2024-09-17 06:59:41.580 Status: zigbee2mqttkabel: Discovered: Küchekaffee Bewe (Power outage count)/Küchekaffee Bewe (Power outage count) (unique_id: 0x00158d00026e09a9_power_outage_count_zigbee2mqttkabel)
2024-09-17 06:59:41.582 Status: zigbee2mqtt: Discovered: Wohnzimmerlicht (Effect)/Wohnzimmerlicht (Effect) (unique_id: 0xbc33acfffe27ffdd_effect_zigbee2mqtt)
2024-09-17 06:59:41.593 Status: zwave2mqtt: Discovered: nodeID_34 (nodeID_34_battery_level)/nodeID_34 (nodeID_34_battery_level) (unique_id: zwavejs2mqtt_0xeae3576a_34-128-0-level)
2024-09-17 06:59:41.694 Status: zwave2mqtt: Discovered: nodeID_34 (nodeID_34_battery_islow)/nodeID_34 (nodeID_34_battery_islow) (unique_id: zwavejs2mqtt_0xeae3576a_34-128-0-isLow)
2024-09-17 06:59:41.781 Status: zigbee2mqttkabel: Discovered: wohnzimmer multisensor/wohnzimmer multisensor (unique_id: 0x00158d0002b60a7d_battery_zigbee2mqttkabel)
2024-09-17 06:59:41.783 Status: zigbee2mqtt: Discovered: Speisekammerlicht (Effect)/Speisekammerlicht (Effect) (unique_id: 0x000b57fffe9a1c74_effect_zigbee2mqtt)
2024-09-17 06:59:41.795 Status: zwave2mqtt: Discovered: nodeID_34 (nodeID_34_event_general_purpose)/nodeID_34 (nodeID_34_event_general_purpose) (unique_id: zwavejs2mqtt_0xeae3576a_34-156-0-state-0)
2024-09-17 06:59:41.903 Status: EventSystem: Queue thread stopped...
2024-09-17 07:00:00.400 Status: Notification: Battery Low: 2 moist (Level: Low)
2024-09-17 07:00:00.400 Notification sent (email) => Success
2024-09-17 07:00:00.400 Status: Notification: Battery Low: 2 temp (Level: Low)
2024-09-17 07:00:00.400 Status: Notification: Battery Low: 2 lux (Level: Low)
2024-09-17 07:00:00.401 Status: Notification: Battery Low: 2 fert (Level: Low)
2024-09-17 07:00:00.401 Notification sent (email) => Success
2024-09-17 07:00:00.401 Status: Notification: Battery Low: 3 moist (Level: 6 %)
2024-09-17 07:00:00.401 Status: Notification: Battery Low: 3 temp (Level: 6 %)
2024-09-17 07:00:00.402 Notification sent (email) => Success
2024-09-17 07:00:00.402 Status: Notification: Battery Low: 3 lux (Level: 6 %)
2024-09-17 07:00:00.402 Status: Notification: Battery Low: 3 fert (Level: 6 %)
2024-09-17 07:00:00.402 Status: Notification: Battery Low: 6 moist (Level: 3 %)
2024-09-17 07:00:00.403 Status: Notification: Battery Low: 6 temp (Level: 3 %)
2024-09-17 07:00:00.403 Notification sent (email) => Success
2024-09-17 07:00:00.403 Status: Notification: Battery Low: 6 lux (Level: 3 %)
2024-09-17 07:00:00.403 Status: Notification: Battery Low: 6 fert (Level: 3 %)
2024-09-17 07:00:00.403 Status: Notification: Battery Low: Garage - Sensor (Level: Low)
2024-09-17 07:00:00.404 Status: Notification: Battery Low: thermostat_notification_power_management_battery_maintenance_status (Level: Low)
2024-09-17 07:00:00.404 Notification sent (email) => Success
2024-09-17 07:00:00.404 Status: Notification: Battery Low: nodeID_185_thermostat (Level: Low)
2024-09-17 07:00:05.533 Notification sent (http) => Success
2024-09-17 07:00:05.573 Notification sent (telegram) => Success
2024-09-17 07:00:05.676 Notification sent (http) => Success
2024-09-17 07:00:05.727 Notification sent (telegram) => Success
2024-09-17 07:00:05.806 Notification sent (http) => Success
2024-09-17 07:00:05.851 Notification sent (telegram) => Success
2024-09-17 07:00:05.940 Notification sent (http) => Success
2024-09-17 07:00:05.998 Notification sent (telegram) => Success
2024-09-17 07:00:06.079 Notification sent (http) => Success
2024-09-17 07:00:06.184 Notification sent (telegram) => Success
2024-09-17 07:00:06.193 Notification sent (http) => Success
2024-09-17 07:00:06.352 Notification sent (telegram) => Success
2024-09-17 07:00:06.357 Notification sent (http) => Success
2024-09-17 07:00:06.473 Notification sent (http) => Success
2024-09-17 07:00:06.577 Notification sent (telegram) => Success
2024-09-17 07:00:06.627 Notification sent (http) => Success
2024-09-17 07:00:06.739 Notification sent (http) => Success
2024-09-17 07:00:06.880 Notification sent (http) => Success
2024-09-17 07:00:06.901 Notification sent (telegram) => Success
2024-09-17 07:00:07.030 Notification sent (http) => Success
2024-09-17 07:00:07.147 Notification sent (http) => Success
2024-09-17 07:00:07.230 Notification sent (telegram) => Success
2024-09-17 07:00:07.266 Notification sent (http) => Success
2024-09-17 07:00:07.377 Notification sent (http) => Success
2024-09-17 07:00:07.518 Notification sent (telegram) => Success
2024-09-17 07:00:07.761 Notification sent (telegram) => Success
2024-09-17 07:00:07.972 Notification sent (telegram) => Success
Jens
