Cool SP / Fan Mode not discovered, is there a workaround ?
Posted: Friday 13 September 2024 21:41
Domoticz running with ZWaveJS and MQTT AutoDiscover.
All works well except Domoticz does not discover "Cooling SetPoint" or "Fan Mode" on thermostat.
I only need to set these two devices once per day.
Is there a method to use cron thru MQTT or ZWaveJS and bypass Domoticz ?
Or even scheduling a scene in ZWaveJSUI would work. Can I do that ?
Thanks in advance.
Thanks in advance.
