Qouad WallMote
PeterRozenveld
Qouad WallMote
Post by PeterRozenveld »
I created a script, which has a trigger as a device. Now I want the Wallmote to turn off after 1 sec. If I give a direct off command in the script , when that Wall mote turns on, a 2nd script is not executed !
De reset:
		devices = {
			'Badk_1_Switch'
	    local Bdk1 = domoticz.devices('Badk_1_Switch') --  De Wallmote switch 1
	    if Bdk1.state == 'On' then
	    domoticz.devices('Badk_1_Switch').switchOn.forSec(2)
And the 2 the script , which needs to be started:
		timer = {
			'every minute',				-- causes the script to be called every minute
	execute = function(domoticz, timer)
	    local Zld2 = domoticz.devices('Zolder_CV-Q2') --  De Ketel
        domoticz.devices('Zolder_CV-Q2').switchOn().forMin(2)
Renaming the switch to a simple one also fails me for Zld2, but that's another concern
The 2nd script , the time should be 20 minutes, but this is for testing
Hopefully someone can point the way
Peter
Re: Qouad WallMote
The second script is run every minute and not triggered by a device change. Chances are small it will find the wallmote on if you switch it off after 2 seconds...
Put some log statement in the script to see if it is running.
PeterRozenveld
Re: Qouad WallMote is een van de volgende
I changed it a bit too much, thanks for your help.
Since it's been a while , I'll make a new topic.
I also bought different remote switch. I have also been working on that for a while.
