Energy dashboard behind nginx proxy
Posted: Friday 06 September 2024 15:26
Version: 2024.7
Platform: raspberry pi 3, Ubuntu 22.04.4 LTS
Plugin/Hardware: Rpi3
really delighted with the new energy dashboard! Looks slick and give good insight.
When playing with it, I was reminded I have a seperate port open in my router, leading to the raspberry pi with domo.
But since I also run a nginx reverse proxy I decided to proxy domo as well, following https://www.domoticz.com/wiki/WebServer_Proxy
(code below)
This works well, but to my surprise the energy dashboard (and only that page!) does display, but without values (apart from zero's).
Checking energy dashboard either via domo's internal IP, or the seperate port and external URL, gives the correct values...
This is via different browsers, incognito windows etc.
Does anyone recognises this, and have a solution?
Domo 2024.7 runnig on a raspberry pi 3, Ubuntu 22.04.4 LTS
(I commented the 2 lines because I have domo running with https )
(code below)
location /domoticz {
rewrite ^/domoticz/?(.*) /$1 break;
proxy_http_version 1.1;
proxy_read_timeout 90;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Scheme $scheme;
# proxy_set_header Upgrade $http_upgrade;
# proxy_set_header Connection $connection_upgrade;
add_header X-Frame-Options SAMEORIGIN;
proxy_pass https://192.168.1.22;
