- Spoiler: show
Start script after specific sunrise time
jberinga
- Domoticz version: 2024.7
Is it possible to execute this script when the sunrise is after 6:50?
willemd
- Domoticz version: 2026.3
Re: Start script after specific sunrise time
So you want to take some action betweeb 6:30 and 7:15 but only if sunrise is after 6:50?
I would then trigger the script with the between 6:30 and 7:15 condition and then in the script test whether sunrise is after 6:50 before doing any further action.
I see in the dzVents wiki there is a "sunriseInMinutes" time property, so you should be able to use that for the 6:50 sunrise test.
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
FlyingDomotic
- Domoticz version: 2020.2
Try with an uppercase "I" in "sunriseInMinute" (things are case sensitive).
jberinga
Correct and that has been tested but I got the error "attempt to index a nil value (field 'sunriseinMinutes')".willemd wrote: Tuesday 03 September 2024 10:59 So you want to take some action betweeb 6:30 and 7:15 but only if sunrise is after 6:50?
But FlyingDomotic got a excelent point
Made the change and I will see what happens tomorrow morning.FlyingDomotic wrote: Tuesday 03 September 2024 12:28 Try with an uppercase "I" in "sunriseInMinute" (things are case sensitive).
- habahabahaba
- Domoticz version: 2024.4
execute = function(domoticz, trigger)
local currentDate = os.time()
local setTime1 = '06:30'
local time1 = os.date("%Y-%m-%d "..setTime1, currentDate)
local time1toStamp = domoticz.time.dateToTimestamp(time1)
local setTime2 = '07:15'
local time2 = os.date("%Y-%m-%d "..setTime2, currentDate)
local time2toStamp = domoticz.time.dateToTimestamp(time2)
local minutesToSunrise = domoticz.time.sunriseInMinutes
local time3 = os.date("%Y-%m-%d 00:00", currentDate)
local CurrentSunriseTimeStamp = domoticz.time.dateToTimestamp(time3) + minutesToSunrise * 60
local todaySunriseTime = domoticz.time.timestampToDate(CurrentSunriseTimeStamp,'%Y-%m-%d time')
domoticz.log('time 1 stamp: '.. time1toStamp, domoticz.LOG_ERROR)
domoticz.log('Time1: '.. time1, domoticz.LOG_ERROR)
domoticz.log('time 2 Stamp: '.. time2toStamp, domoticz.LOG_ERROR)
domoticz.log('time2: '.. time2, domoticz.LOG_ERROR)
domoticz.log('CurrentSunriseTimeStamp: '.. CurrentSunriseTimeStamp, domoticz.LOG_ERROR)
domoticz.log('todaySunriseTime: '.. todaySunriseTime, domoticz.LOG_ERROR)
if CurrentSunriseTimeStamp > time1toStamp and CurrentSunriseTimeStamp < time2toStamp then
domoticz.log('Its MATCH!!!', domoticz.LOG_ERROR)
