Resending raw IR codes with Tuya ZS06 problems
Posted: Tuesday 03 September 2024 4:55
Just got my Tuya ZS06
ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus
Zigbee2MQTT version
1.39.1
Type of Coordinator
zStack3x0
Coordinatorrevision
20231111
Coordinator IEEE-adress
0x00124b002f8ac433
Frontend version
0.7.4
Zigbee-herdsman-converters version
19.72.0
Zigbee-herdsman version
0.55.3
I learned it with an on/off code from my TV-remote, created a file and kicked it off as a string in the Domoticz widget.
and it works both within Z2M and with a mosquitto_pub script triggered from Domoticz. The message payload is different for every time the button on Remote control is pressed but the stored one above always works.
Then I used the same procedure (and the same rules apply with different codestrings every from my A/C IR remote but on/off button gives a much longer code:
This code newer has worked ( I have tried many times with different codes.)
MQTT Explorer shows there are differences in the received string after about 200 characters.
Is there a limitation somewhere in the system that sets a limit ob the payload ??
Or is somebody aware of why this longer string can not be sent back correctly either through Z2M or moquitto/MQTT Explorer
I have read almost everything on this subject but I dont understand how to make the second codestring work in the same way as the first...
Thanks in advance for your inputs!
Zigbee2MQTT version
1.39.1
Type of Coordinator
zStack3x0
Coordinatorrevision
20231111
0x00124b002f8ac433
Frontend version
0.7.4
19.72.0
0.55.3
mosquitto_pub -t 'zigbee2mqtt/0x0cae5ffffe9223c7/set' -m '{"ir_code_to_send":"BXsjvxE0AsABA6oGNALgCwFAF0ADQAFAB+AHA+ADAUAb4AcBQBPAA0ABwAvABwkRnnsj6Qg0Av//4AoHAgg0Ag=="}'Then I used the same procedure (and the same rules apply with different codestrings every from my A/C IR remote but on/off button gives a much longer code:
mosquitto_pub -t 'zigbee2mqtt/0x0cae5ffffe9223c7/set' -m '{"ir_code_to_send":"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"}'This code newer has worked ( I have tried many times with different codes.)
