install.domoticz.com certificate expired on the 1st of September
Posted: Monday 02 September 2024 19:37
by docnl
Installation is no longer possible unless you use the --insecure parameter. You then get the default start screen but i'm not able to start installation. But this could be another problem.
Re: install.domoticz.com certificate expired on the 1st of September
Posted: Tuesday 03 September 2024 8:24
by gizmocuz
Should be solved now, thanks for reporting.
Server was under attack some days ago and some drastic changes have been made
Posted: Tuesday 03 September 2024 12:34
by FlyingDomotic
gizmocuz wrote: ↑Tuesday 03 September 2024 8:24
"Drastic" seems to be the right word, as I'm now forced to tell I'm human every few minutes, with around 20% failure leading to a loop
Retrying some time later fixed the issue up to now.
