I recently bought some New Zvawes devices
one Aeotech multisensor 7 ZWA024
and
several fibaro roller shutter 4 FGR-224
But neither work correctly, It seems I miss the correct XML files for Domoticz to recognise them properly, I'm using openZwave library
I tried to create an xml file for the ZWA024 that I found on internet
https://github.com/jeedom/plugin-openzw ... ved/config
and i modified the manufacturer_specific.xml as well
but so far even if the system detect most of the info from the multisensor, I cant access any parameters to customize anything for the device.
I try to remove re add the device several time but it didnt fix anything...
on my first try the sensor device showed as unknown
Thx for any help you can provide
unrecognised zwave Device
noctanvol
- multisensor.jpg (120.53 KiB) Viewed 5294 times
mantoz
- Domoticz version: 2024.7
Re: unrecognised zwave Device
Sorry @noctanvol, just a little late
but try checking my old post here viewtopic.php?p=309942
and you can find some more info to get the FGR-224 working with OpenZWave.
