Python Script for reading Sun600G3-EU-230
Posted: Saturday 31 August 2024 8:55
by Grizzly2000
I'd like to present my Code for reading Sun600G3-EU-230 Solar plant
from bs4 import BeautifulSoup
import requests
def get_power_value():
    # Send the request with Basic Authentication
    url = 'http://192.168.178.XXX/status.html'
    username = 'XXXXXXX'
    password = 'XXXXXXX'
    response = requests.get(url, auth=(username, password))
    if response.status_code != 200:
        raise Exception(f"Failed to fetch page, status code: {response.status_code}")
    # Parse the HTML content
    soup = BeautifulSoup(response.text, 'html.parser')
    # Find all script tags
    scripts = soup.find_all('script')
    # Regular expression to match JavaScript variable assignments
    var_regex = re.compile(r'var\s+(\w+)\s*=\s*"([^"]+)"')
    # Initialize variables
    webdata_now_p = None
    webdata_today_e = None
    # Search through the script contents
    for script in scripts:
        script_content = script.string
        if script_content:
            for match in var_regex.finditer(script_content):
                var_name, var_value = match.groups()
                if var_name == 'webdata_now_p':
                    webdata_now_p = var_value
                elif var_name == 'webdata_today_e':
                    webdata_today_e = var_value
    # Ensure both values are found
    if webdata_now_p is None or webdata_today_e is None:
        raise Exception("Failed to find one or both variables in the HTML")
    # Convert webdata_today_e to float and multiply by 1000
    try:
        webdata_today_e = float(webdata_today_e) * 1000
    except ValueError:
        raise Exception(f"Error converting webdata_today_e to float: {webdata_today_e}")
    print("Aktuell:", webdata_now_p)
    print("Gesamt:", webdata_today_e)
    # Return the extracted values
    return webdata_now_p, webdata_today_e
You have to install beautiful soap... the device reads the status page of the inverter and extracts two values.
