Save Search
Posted: Tuesday 27 August 2024 11:59
by Jemand
I have over 100 devices and when I search for a device at the top of the page and click on "Log" or "Edit" and come back to the switches overview the search is empty and I have to search for the device again.
I've built a small javascript which I included in the page to fix that. The script saves the last search input and restores the search when I enter the page again. This works perfect but it would be great to have this within domoticz natively like in the devices-search.
Here is my Javascript for this:
Re: Save Search
Posted: Tuesday 27 August 2024 15:05
by Kedi
Nice.
+1
Re: Save Search
Posted: Tuesday 27 August 2024 16:17
by gizmocuz
Very nice indeed!
Does this also work when you switch for instance from the temperature tab to the utility tab?
If you want, please make a github PR with your changes
Re: Save Search
Posted: Saturday 31 August 2024 12:19
by Jemand
My Script was just for LightSwitches as I don't have too many other devices where I need to search.
But here is an updated version for every domoticz-page. You can include this script in your domoticz directory under www/styles/default/custom.js:
// Function to extract the page type from the URL
function getCurrentPageType() {
const hash = window.location.hash;
const match = hash.match(/#\/([^/?]+)/);
return match ? match[1].toLowerCase() : 'unknown';
// Function to save the search term
function saveSearch(searchTerm) {
const pageType = getCurrentPageType();
if (pageType !== 'unknown') {
if (searchTerm) {
localStorage.setItem(`savedSearch_${pageType}`, searchTerm);
} else {
localStorage.removeItem(`savedSearch_${pageType}`);
// Function to load the saved search term
function loadSearch() {
return pageType !== 'unknown' ? (localStorage.getItem(`savedSearch_${pageType}`) || '') : '';
// Function to trigger the search
function triggerSearch(searchInput) {
if (getCurrentPageType() === 'unknown') return;
// Trigger the 'input' event
const inputEvent = new Event('input', { bubbles: true, cancelable: true });
searchInput.dispatchEvent(inputEvent);
// Trigger the 'change' event
const changeEvent = new Event('change', { bubbles: true, cancelable: true });
searchInput.dispatchEvent(changeEvent);
// Trigger the 'keyup' event
const keyupEvent = new KeyboardEvent('keyup', { bubbles: true, cancelable: true, key: 'Enter', keyCode: 13 });
searchInput.dispatchEvent(keyupEvent);
// Function to clear the search
function clearSearch(searchInput) {
searchInput.value = '';
saveSearch('');
triggerSearch(searchInput);
// Function to initialize the script
function initSearchPersistence() {
function setupSearchInput() {
const searchInput = document.querySelector('.livesearch.jsLiveSearch');
if (searchInput) {
// Load the saved search term
const savedValue = loadSearch();
if (savedValue && searchInput.value !== savedValue) {
searchInput.value = savedValue;
// Delayed triggering of the search
setTimeout(() => triggerSearch(searchInput), 500);
// Event listener for changes in the search field
searchInput.addEventListener('input', function() {
saveSearch(this.value);
// Find and set up the clear button
const clearButton = searchInput.parentElement.querySelector('.fa-circle-xmark');
if (clearButton) {
clearButton.addEventListener('click', function() {
clearSearch(searchInput);
// Remove the interval as the search field has been found
clearInterval(searchCheckInterval);
// Regularly check if the search field is available
const searchCheckInterval = setInterval(setupSearchInput, 100);
// Function to handle URL changes
function handleUrlChange() {
// Only initialize if a search input exists on the page
if (document.querySelector('.livesearch.jsLiveSearch')) {
initSearchPersistence();
// Initialization when loading the page
handleUrlChange();
// Listener for hash changes
window.addEventListener('hashchange', handleUrlChange);
Re: Save Search
Posted: Monday 02 September 2024 13:05
by gizmocuz
Thank you for this! Could you make a git pull request with the changes?
