dzVents script to load "energieweerbericht"
willemd
Post by willemd »
For anyone interested to load the data of the "energieweerbericht" of the Netherlands Energy Dashboard, here is a dzVents script to do exactly that.
https://ned.nl/nl/energieweerbericht#Energieweerbericht
Energieweerbericht is the predicted solar and wind energy production for the week ahead for The Netherlands. The scripts loads the daily totals and that info can be used to make some guess of the future dynamic energy prices for the week ahead (combined with other info). With some changes to the API parameters you could also load hourly data or only data for a specific region. Please check the NED.nl API documentation.
For my own use, I am displaying a stacked bar in dashticz of the two counters to see the total predicted production.
To use the script you have to create two managed counters, one to hold the predicted wind energy production and one to hold the predicted solar energy production. You also need an account at NED.nl and need to request an API token and store that token in a Domoticz user variable. Please adapt the IDX numbers on line 16,17 and 18 for your installation.
		timer = {
			'every hour' -- time trigger
		httpResponses = {
			'NEDtrigger' -- must match with the callback passed to the openURL command
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'energieweerbericht',
	    local idxNEDwindforecast=223 -- two managed counters to hold the values as received in the API response
	    local idxNEDsolarforecast=224
	    local idxNEDtoken=23  -- token to be requested at NED.nl and to be stored in a user variable
	    local NEDtoken=domoticz.variables(idxNEDtoken).value
        local startdate=os.date("%Y-%m-%d")
        local cleardate=os.date("%Y-%m-%d",os.time()-24*60*60) -- yesterday
        local enddate=os.date("%Y-%m-%d",os.time()+7*24*60*60)  -- data can be requested 7 days ahead
        local baseURL="https://api.ned.nl/v1/utilizations?"
		if (item.isTimer) then
		    -- first request wind data, type is 1
		    local URLparameters="point=0&type=1&granularity=6&granularitytimezone=1&classification=1&activity=1&validfrom[after]="..startdate.."&validfrom[strictly_before]="..enddate
		    -- check API documentation at NED.nl for more info about parameters
            local totalURL=baseURL..URLparameters
			domoticz.openURL({
				url = totalURL,
				method = 'GET',
				callback = 'NEDtrigger', -- see httpResponses above.
				headers = { ['X-AUTH-TOKEN'] = NEDtoken ,
				            ['accept'] = 'application/xml'
			-- now request solar data, type is 2
			URLparameters="point=0&type=2&granularity=6&granularitytimezone=1&classification=1&activity=1&validfrom[after]="..startdate.."&validfrom[strictly_before]="..enddate
			domoticz.openURL({
				url = totalURL,
				method = 'GET',
		if (item.isHTTPResponse) then  -- process the API response
            -- this will be done once for each type separately
			if (item.ok) then
			    --domoticz.log('start dumptable ned', domoticz.LOG_INFO)
    			--domoticz.utils.dumpTable(item.xml.response.item)  -- dumpTable can be used for debugging
    			--domoticz.log('end dumptable ned', domoticz.LOG_INFO)
				if (item.isXML) then
				    -- clear yesterday's data from the meter table (but not meter_calendar)
				    domoticz.openURL("http://127.0.0.1:8080/json.htm?type=command&param=deletedatapoint&idx="..idxNEDwindforecast.."&date="..cleardate.."%2000:00:00")
                    domoticz.openURL("http://127.0.0.1:8080/json.htm?type=command&param=deletedatapoint&idx="..idxNEDsolarforecast.."&date="..cleardate.."%2000:00:00")
				    -- process future values for week ahead
                    for day=1,7 do
                        local requestType=domoticz.utils.stringSplit(item.xml.response.item[day].type,"/")[3]
                        local capacity=item.xml.response.item[day].capacity
                        local capacityDate=domoticz.utils.stringSplit(item.xml.response.item[day].validto,"T")[1]
                        domoticz.log("type "..requestType.." date "..capacityDate.." capacity "..capacity,domoticz.LOG_INFO)
                        if requestType=="1" then  -- wind date
                            -- this will insert into the meter_calendar table but the future values will not show up in the graph, only the past and current.
                            domoticz.devices(idxNEDwindforecast).updateHistory(capacityDate,"0"..";"..capacity)
                             -- this will insert into the meter table and those future values will show up in the graph
                             domoticz.devices(idxNEDwindforecast).updateHistory(capacityDate.." 00:00:00","0;"..capacity)
                             if capacityDate==startdate then
                                domoticz.devices(idxNEDwindforecast).updateCounter(capacity) -- counter icon shows value of today
                            if requestType=="2" then -- solar data
                                domoticz.devices(idxNEDsolarforecast).updateHistory(capacityDate,"0"..";"..capacity) -- this will insert into the meter_calendar table but the future values will not show up in the domoticz graph, only the past and current.
                                domoticz.devices(idxNEDsolarforecast).updateHistory(capacityDate.." 00:00:00","0;"..capacity) -- this will insert into the meter table and those future values will show up in the graph
                                    domoticz.devices(idxNEDsolarforecast).updateCounter(capacity)
				    domoticz.log('is not xml', domoticz.LOG_INFO)
				domoticz.log('There was a problem handling the NED request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Tukker
Domoticz version: 2023.2
Re: dzVents script to load "energieweerbericht"
Post by Tukker »
Great Willemd!
Bugs bug me.
Snakfy
Post by Snakfy »
Great WillemD Still usefull after all this time!
Also the others things your doing for the community! :D :D
