I am new to this forum but an old user of Domoticz
Using Domoticz for many years now I decided to add an RFX868XL module to get data from my Ecowitt WS90 sensor
The problem is that once connected to the raspberry pi running domoticz I cannot find the correct protocol in the domoticz configuration interface"set mode"
I needed to select "FineOffset" but it is not in the list presented by Domoticz interface for the RFX868 module but it is available when using RFXmngr.exe on windows.
The strange thing is that "FineOffset"is available when choosing the RFX433 in the hardware configuration, but my need is to have it for the RFX868
Did I miss something ?
Patrick
Using RFX868,problems with mode selection
PatrickH67
- Domoticz version: 2024.4
- gizmocuz
Re: Using RFX868,problems with mode selection
Hello Patrick,
Please use the RFXCom RFXManager application to configure your device.
Domoticz will then use these settings
PatrickH67
Thanks for your reply
I have used RFXmngr to configure the requiert mode of my RFX868. So I will check again if I can see the sensor data in Domoticz
