Page 1 of 19
Satel Integra (Security System) with ethernet module
Posted: Tuesday 09 December 2014 21:08
by proohu01
Has anyone tried to integrate the Satel Integra security system into Domoticz yet? There is a detailed protocoll description for the ETHM-1 module.
http://www.satel.pl/en/download/instruk ... l_1.07.pdf
I am not a programmer so it is of no use to me
It should be possible: (link in Dutch)
http://www.kopbeveiliging.nl/producten/ ... ng+leerdam
Re: Satel Integra (Security System) with ethernet module
Posted: Friday 19 December 2014 0:46
by free_nsc
Also interested in integrating Satel Integra with RaspberryPI so I am currently looking into the documentnantion
Posted: Saturday 03 January 2015 0:25
by free_nsc
@proohu01 I have found a script by xury which allowed me to get on to the right path - I have successfully send a frame to read my Satel integra 128wrl status.
I currently have 2x relay switches in my integra output lines which control the two zones in my gas Boiler. For this purpose, my goal is to be able to read my ABAX Thermometers and display/use them in scenes to then control Central Heating using domoticz instead of integra.
I have read out the temperature into Hex string using Bash script and can convert it into dec temperature value so this could be used in domoticz.
My problem here is that I am beginner when it comes to Domoticz and LUA so not sure how to return this value into Domoticz's virtual device.
I need someone's help as to how to add virtual thermometer device that will have its reading taken from the bash script which will polls temp. from Integra's ATD-100 inputs. Once we have this sorted we can read status of any other inputs/outputs etc.
Posted: Monday 05 January 2015 9:12
by proohu01
I'm eager to learn how you are able to get information from your Satel. Are you also able to determine if it ARMED or not? Please do tell
Updating the virtual thermometer can be done by JSON or LUA.
For JSON, have a look at Wiki:
http://www.domoticz.com/wiki/Domoticz_A ... emperature
It should be something like this
DOMOTICZ_SERVER="192.168.0.104:8080"
IDX="67"
TEMP="25"
curl -s -i -H "Accept: application/json" "http://$DOMOTICZ_SERVER/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP"
If you want to do it from LUA, have a look at this post:
http://www.domoticz.com/forum/viewtopic.php?f=12&t=3692
Posted: Tuesday 06 January 2015 2:29
by free_nsc
Important Note: Since I wrote the below post user Fanton has implemented full integration with Integra so we no longer require a script to parse the ATD100.
He has spent extra time and added support for ATD100 just based on my troubleshooting and experiments but without even having this hardware! All you need to do is rename one of the zone devices in Integra to contain "ATD100". Then Disable/Enable Satel hardware and voila! Fair play Fantom and thanks for hard work.
Here we go - this code is only a sample. Create a bash file change relevant variables below and then save the file and make it executable.
This is only designed to execute command 7D which is reading Zone temperatures.
In example below I am specifically reading zone x19 which is my SatelLivingTemp sensor. In integra this is zone number 25 = so converting into hex = 19. Next two bytes is crc x4F\xA8. I have calculated and hardcoded CRC. If you change the zone you want to query then you will need to calculate CRC using INT-RS CRC program (google it or else I will try attach it for you) or ideally incorporate CRC calculation into this script. I wasnt able to get correct CRC using bash script.
#!/bin/bash
# Satelicz v.1.0 by free_nsc
# Reads temperature from Satel inputs
# SERVERPI is Domoticz IP and port
# IDX devid
# NVALUE is the function in Domoticz device 0 holds temperature value
SERVERPI="192.168.1.49:8080"
IDX="7"
NVALUE="0"
SATELIP="192.168.1.7"
SATELPORT="7094"
hex="$(echo -en "\xFE\xFE\x7D\x19\x4F\xA8\xFE\x0D" | nc $SATELIP $SATELPORT | hexdump -v -e ' 1/1 "%02X" " "')"
hexarray=($hex)
echo -n "Satel frame response : "
echo $hex
echo "----------------------------------------"
# echo "Display Byte 03 of the hex array"
# echo -n ${hexarray[3]}
echo -n "Current sensor: "
# This is just to keep list of current sensors and to make sure we are updating the correct device as returned from Integra
case ${hexarray[3]} in
"1C") echo "SatelOutsideTemp" ;;
"19") echo "SatelLivingTemp" ;;
"20") echo "SatelBed1FloorTemp" ;;
"17") echo "SatelBed2FloorTemp" ;;
esac
# Satel returns temp values as follows
# starting from -55.0'C = x00 , -54.5'C = x01, 00.0'c = x6E
# Reading temperature from byte 05
# Convert from HEX to Decimal value
# then have to reduce absolute value by 110 and divide the result by 2
lcTempHex=${hexarray[5]}
lnTempRaw="$(echo $((16#$lcTempHex)))"
lnTempRaw="$(echo $[($lnTempRaw - 110)])"
lcTEMP=$(echo "scale=2; $lnTempRaw / 2.0" | bc)
echo -n "Current temperature reading : "
echo $lcTEMP
echo "Updating Domoticz Device ID : " $IDX
curl -s -H "Accept: application/json" "http://$SERVERPI/json.htm?type=command¶m=udevice&idx=$IDX&nvalue=$NVALUE&svalue=$lcTEMP"
echo "Done."
In domoticz create virtual thermometer and activate it then write down the IDX and update this in the script above so the JSON query updates the correct virtual sensor.
Finally, you can add script into crontab so it runs periodically e.g. every 5 or 10 mins
Going back to CRC calculation. Below here with the code from stackoverflow to calc CRC. Unfortunately, this didn't work for me so I have hardcoded CRC for now:
function awk_calc_crc16()
output=$(echo $1 | awk 'function ord(c){return chmap[c];}
BEGIN{c=65535; for (i=0; i < 256; i++){ chmap[sprintf("%c", i)] = i;}}
split($0, chars, "");
for(i = 1; i <= length(chars); i++)
cval=ord(chars[i])
e=and(xor(c, ord(chars[i])), 0x00FF);
s=and(lshift(e, 4), 0x00FF);
f=and(xor(e, s), 0x00FF);
r=xor(xor(xor(rshift(c, 8), lshift(f, 8)), lshift(f, 3)), rshift(f, 4));
c=r;
END{c=xor(c, 0xFFFF); printf("%hu", c);}')
echo $output;
Posted: Tuesday 06 January 2015 9:22
by proohu01
Wonderful! That is something I can work with. Thank you for that.
I do not (yet) have any temperature sensors connected to my Satel, but I am able to determine whether or not a zone or partition is armed or not. For example:
Changing "\xFE\xFE\x7D\x19\x4F\xA8\xFE\x0D" in your script to "\xFE\xFE\x09\xD7\xEB\xFE\x0D" gives me an output like:
pi@domoticzpi ~/domoticz/scripts $ ./satel.sh
Satel frame response : FE FE 09 01 00 00 00 7D AC FE 0D
Where "01" means partition 1 is ARMED
I'm not sure if I've got the CRC calculating bit under control. I may have to read that part a couple of times more.
Posted: Tuesday 06 January 2015 13:08
by free_nsc
No worries glad to be of help. I'm only figuring it out myself now as I go.
You're getting right frame response so you got it!
Have you got the crc script working? if so share the code please.
How do you plan on using zone/partition statuses within Domoticz?
Posted: Wednesday 07 January 2015 13:37
by proohu01
I tried the CRC script but it doesn't work for me. I did find a Python (v3) script in the meantime that does also works for me and has a working CRC included.
https://github.com/mkorz/IntegraPy
I want to be able to detect if the alarm has been (dis)armed or if a door or window is open for a long period of time. By running this script every minute, I suppose I would be able to change the state of some virtual switches in Domoticz. Than, create some LUA logic and/or notification around that. (future stuff)
Posted: Thursday 08 January 2015 0:18
by free_nsc
I came across this script as well but wasn't able to run it cause I ran it as python as opposed to python3. Now it works
Posted: Friday 24 July 2015 15:25
by fantom
Few days ago i started implementig module for Satel Integra.
I have a basic version now.
I can send the compiled version to test.
Fantom
Posted: Friday 24 July 2015 23:48
by free_nsc
Fantom please send it on and we will test.
Posted: Saturday 25 July 2015 12:37
by proohu01
Yep, me two please. Can you also tell us what it can and cannot do?
Posted: Saturday 25 July 2015 17:27
by fantom
Now its only reading state of zones and output.
In this week I will add outputs switching.
Now I enabled debug mode, than you may see many logs from this module.
The biggest problem is add new type of device to domoticz. Any existing do not match to Integra. Now I using 'percentage' and 'generalswitch'
But this code is good for developing.
Link :
https://docs.google.com/uc?authuser=0&i ... t=download
Fantom
ps. Let me know how it works (or not works)
Posted: Saturday 25 July 2015 17:47
by proohu01
I am not quite sure if I should just trust this! Is your code public? Why is the executable file called "domoticz"? That does not make sence to me.
Perhaps you should give us some more info on how to install and perhaps some screenshots.
Thank you.
Posted: Sunday 26 July 2015 7:58
by fantom
More faith in people
I get branch 2659, added my source files and compiled under raspberry pi (linux). Are you use linux or windows ?
This is normal version of domoticz. If you use linux, You may temporary replace binary file 'domoticz', or only stopped original domoticz and run my file.
Basic sources i dropped some time ago :
http://www.domoticz.com/forum/tracker.php?p=2&t=558
I think Gizmocuz has a vacation and does not speak from 2-3 weeks.
EDIT. I added output switching today.
Fantom
Posted: Sunday 26 July 2015 20:42
by fantom
What would have also added?
I planning add switch "armed" and sensor "alarm"
Fantom
Posted: Monday 27 July 2015 22:38
by free_nsc
fantom wrote:What would have also added?
Fantom
Im on holidays at the moment but will be testing it from tomorrow.
Add temperature sensors reading (7D) or have you already added that in?
Posted: Tuesday 28 July 2015 15:52
by proohu01
fantom wrote:More faith in people
Fantom
Hello fantom,
I am sorry I didn't trust it right away
One can never be too careful! (right?) I applaud anyone willing to add new hardware support to Domoticz. Especially when it is hardware I use
However, it will take quite some time before I am able to test this on my system. I'll get back to you when I am able to test.
Posted: Tuesday 28 July 2015 21:02
by fantom
I upload the newest version :
https://docs.google.com/uc?id=0B9UIjleS ... t=download
I added password (user code) field to configuration and handled broken connection.
Fantom
ps. Please, uncheck 'topic solved'
Posted: Thursday 06 August 2015 23:54
by free_nsc
Fantom - I downloaded the file but it wont compile on RPi for me. it's quite large - 60Mb.
It does not run successfully. Any ideas?
