Influxdb error
roblom
Influxdb error
Post by roblom »
Recently my sd card probably died. I managed to get things up and running again on a fresh sd card but only influxdb gives problems.
The domoticz log gives a lot of error lines like below.
Error: InfluxLink: Error sending data to InfluxDB server! (check address/port/database/username/password)
journalctl gives a lot of error lines like below.
systemd[1]: influxdb.service: Start operation timed out. Terminating.
Does somebody know a solution?
Re: Influxdb error
If you installed influx DB from fresh (and so latest influx DB version) you perhaps need the V2 authentication method?
https://www.domoticz.com/wiki/Influxdb
