Minimize P1 power_delivery (terugleverkosten verminderen)
Posted: Sunday 11 August 2024 23:29
by Tukker
I want to show a little project that gives insight in power_delivery from your PV panels to the net.
In the Netherlands most people receive the value of the current electricity price for power_delivered, however since 1 July many have to pay about 11 cents for every kWh delivered back to the net.
Delivered kWh to the net used to bring in 27-33 cents per kWh and that is now reduced to 16-22 cents per kWh.
The device I constructed is a little box with an ESP8266 and a green and a red led.
green - power_delivery > 2000 Watt
green and red - power_delivery between 10 and 2000 Watt
red - power consumed
The code for the ESP8266 is
  Rui Santos
  Complete project details at https://randomnerdtutorials.com
  * https://randomnerdtutorials.com/esp32-mqtt-publish-subscribe-arduino-ide/
// Load Wi-Fi library
#ifdef ESP32
  #include <WiFi.h>
#else
  #include <ESP8266WiFi.h>
#endif
#include <PubSubClient.h>
#include <Arduino.h>
// Replace the next variables with your SSID/Password combination
const char* ssid = "your-SSID";
const char* password = "your-password";
// Add your MQTT Broker IP address, example:
const char* mqtt_server = "192.168.1.144";
WiFiClient myClient;
PubSubClient client(myClient);
long lastMsg = 0;
char msg[50];
int value = 0;
// LED Pin for testing
// const int ledPin = 2;  // D4 is D4 PLUS the onboard LED
// onboard LOW is ON  D4 low is OFF
const int ledRood = 13;  //  D7
const int ledGroen = 12;  //  D6
void setup() {
  Serial.begin(115200);
  // default settings
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  pinMode(ledRood, OUTPUT);
  pinMode(ledGroen, OUTPUT);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void callback(char* topic, byte* message, unsigned int length) {
  Serial.print("Message arrived on topic: ");
  Serial.print(topic);
  Serial.print(". Message: ");
  String messageTemp;
  for (int i = 0; i < length; i++) {
    Serial.print((char)message[i]);
    messageTemp += (char)message[i];
  Serial.println();
  // Feel free to add more if statements to control more GPIOs with MQTT
  // If a message is received on the topic myoutput , you check if the message is either "on" or "off".
  // Changes the output state according to the message
  if (String(topic) == "my/output") {
    Serial.print("1 Output receveid output : ");
    if(messageTemp == "roodon"){
      Serial.println("4 ledRood ON");
      digitalWrite(ledRood, HIGH);
    else if(messageTemp == "roodoff"){
      Serial.println("5 ledRood OFF");
      digitalWrite(ledRood, LOW);
        if(messageTemp == "groenon"){
      Serial.println("6 ledgGroen ON");
      digitalWrite(ledGroen, HIGH);
    else if(messageTemp == "groenoff"){
      Serial.println("7 ledGroen OFF");
      digitalWrite(ledGroen, LOW);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Subscribe
      client.subscribe("my/output");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  long now = millis();
  if (now - lastMsg > 5000) {
    lastMsg = now;
    // Temperature in Celsius
    temperature = bme.readTemperature();
    // Uncomment the next line to set temperature in Fahrenheit
    // (and comment the previous temperature line)
    //temperature = 1.8 * bme.readTemperature() + 32; // Temperature in Fahrenheit
    // Convert the value to a char array
    char tempString[8];
    dtostrf(temperature, 1, 2, tempString);
    Serial.print("Temperature: ");
    Serial.println(tempString);
    client.publish("esp32/temperature", tempString);
    humidity = bme.readHumidity();
    char humString[8];
    dtostrf(humidity, 1, 2, humString);
    Serial.print("Humidity: ");
    Serial.println(humString);
    client.publish("esp32/humidity", humString); */
The dzvents code in domoticz is
-- PV panels P1 power_delivery indicated by LED lights
-- assumptions:
local P1 = 'Power' -- P1 reading
--local LOGGING = true
    active = true,
    on =
        timer =
            'every minute'-- between 20 minutes before sunrise and 20 minutes aftter sunset'
    logging = {
        level = domoticz.LOG_ERROR, -- domoticz.LOG_DEBUG for debug, to domoticz.LOG_ERROR when all OK
        marker = "----- P1 power_delivery ---------"
-- between 30 minutes after sunrise and 20 minutes before sunset'
    --LOG level: This is the log level you want for this script. Can be domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
    --marker: A string that is prefixed before each log message. That way you can easily create a filter in the Domoticz log to see just these messages.
    execute = function(dz)
        -- domoticz.utils.dumpTable(item.json)   -- dumpTable laat alle waarden zien, mooi voor debugging
        -- collect all input data
        local power_usage = dz.devices(P1).usage -- usage
        local power_delivery = dz.devices(P1).usageDelivered
        -- info only on log level = LOG_DEBUG
        dz.log('Gebruik         : ' .. power_usage, dz.LOG_DEBUG)
        dz.log('Teruglevering   : ' .. power_delivery, dz.LOG_DEBUG)
        if (power_delivery >= 2000) then
          -- groene led aan
            dz.executeShellCommand('mosquitto_pub -d  -t my/output -h 192.168.1.144 -m "roodoff"')
            dz.executeShellCommand('mosquitto_pub -d  -t my/output -h 192.168.1.144 -m "groenon"')
        elseif (power_delivery < 2000) and power_delivery > 10 then
          -- groene led en rode led aan
            dz.executeShellCommand('mosquitto_pub -d  -t my/output -h 192.168.1.144 -m "roodon"')
        elseif (power_delivery <= 10) then
            -- rode led aan
            dz.executeShellCommand('mosquitto_pub -d  -t my/output -h 192.168.1.144 -m "groenoff"')
-- end power_delivery level indicator
Put the box with the green and red led somewhere in the kitchen or near the washing machine and know when is the best time to use energy 'for free'.
PS The code shows the simplicity of using MQTT in Domoticz.
Re: Minimize P1 power_delivery (terugleverkosten verminderen)
Posted: Monday 12 August 2024 0:25
You could also have the ESP listen to MQTT Domoticz/out topic and read the dummy switch showing the energy state (Red/Green)
Then you did not need to write a dzvents script calling external mqtt commands. Only a dzvents script setting the dummy switch state based on energy production.
In that way it seems more logical and better integration of standard Domoticz MQTT.
