Page 1 of 2
Domoticz SMA Inverter error
Posted: Sunday 04 August 2024 15:16
by Bospieper
]Hi,
I've installed the Domoticz-SMA-inverter plugin and installed the files pymodbus en pymodbusTCP.
Unfortunately I'am getting the follow errors:
Schermafbeelding 2024-08-04 150025.png (7.81 KiB) Viewed 2533 times
and
Schermafbeelding 2024-08-04 150846.png (2.99 KiB) Viewed 2533 times
pymodbus 3.7.0
pymodbusTCP 0.2.2
Domoticz 2024.7
Who can tell me more about these errors and a possible solution?
Grz. Piet
Re: Domoticz SMA Inverter error
Posted: Thursday 08 August 2024 7:57
by mvveelen
What plugin exactly are you using? There are several...
Posted: Friday 09 August 2024 0:02
by Bospieper
This one: SMA Solar Inverter (modbus TCP/IP)
Posted: Friday 09 August 2024 8:17
by mvveelen
OK, well I use an external (modified) plugin for the 2 SMA inverters I have:
In the plugin folder, I have a subfolder "Domoticz-SMA-SunnyBoy"
with below plugin.py script.
# SMA Sunny Boy Python Plugin for Domoticz
# Authors: merlot, rklomp
# Based on https://github.com/merlot-dev/Domoticz-SMA-SunnyBoy
<plugin key="SMASunnyBoy" name="SMA Sunny Boy Solar Inverter" author="rklomp" version="1.0.6">
    <description>
        <h2>SMA Sunny Boy Solar Inverter Plugin</h2><br/>
        <h3>Features</h3>
        <ul style="list-style-type:square">
            <li>Register instant power and daily generated energy</li>
        </ul>
    </description>
    <params>
        <param field="Address" label="IP Address" width="200px" required="true"/>
        <param field="Password" label="User group password" width="200px" required="true" password="true"/>
        <param field="Mode1" label="Protocol" width="75px">
            <options>
                <option label="HTTPS" value="https"/>
                <option label="HTTP" value="http"  default="true" />
            </options>
        </param>
        <param field="Mode3" label="Query interval" width="75px" required="true">
            <options>
                <option label="5 sec" value="1"/>
                <option label="15 sec" value="3"/>
                <option label="30 sec" value="6"/>
                <option label="1 min" value="12" default="true"/>
                <option label="3 min" value="36"/>
                <option label="5 min" value="60"/>
                <option label="10 min" value="120"/>
            </options>
        </param>
        <param field="Mode6" label="Debug" width="75px">
            <options>
                <option label="True" value="Debug"/>
                <option label="False" value="Normal" default="true"/>
            </options>
        </param>
    </params>
</plugin>
import requests
import Domoticz
class BasePlugin:
    enabled = False
    lastPolled = 0
    loginSid = None
    baseUrl = None
    headers = {'Content-Type': 'application/json', 'Accept-Charset': 'UTF-8'}
    maxAttempts = 3
    httpTimeout = 1
    def __init__(self):
        return
    def login(self, force=False):
        if not force and self.loginSid is not None:
            return self.loginSid
        try:
            url = "%s/login.json" % self.baseUrl
            payload = '{"pass" : "%s", "right" : "usr"}' % Parameters["Password"]
            r = requests.post(url, data=payload, headers=self.headers, verify=False, timeout=self.httpTimeout)
        except Exception as e:
            Domoticz.Log("Error accessing SMA inverter on %s; %s" % (Parameters["Address"], e))
        else:
            j = r.json()
            try:
                sid = j['result']['sid']
                if sid is None:
                    Domoticz.Error("Unable to login to SMA inverter on %s using supplied password" % Parameters["Address"])
                self.loginSid = sid
                Domoticz.Status("Successfully logged in to SMA inverter on %s" % Parameters["Address"])
                Domoticz.Debug("Received SID: %s" % sid)
            except:
                Domoticz.Log("No valid response from SMA inverter on %s; %s" % (Parameters["Address"], j))
    def logout(self):
        Domoticz.Status("Closing session to SMA inverter on %s" % Parameters["Address"])
        url = "%s/logout.json?sid=%s" % (self.baseUrl, self.loginSid)
        r = requests.post(url, data="{}", headers=self.headers, verify=False, timeout=self.httpTimeout)
        Domoticz.Debug(r.text)
    def onStart(self):
        Domoticz.Debug("onStart called")
        if Parameters["Mode6"] == "Debug":
            Domoticz.Debugging(1)
        else:
            Domoticz.Debugging(0)
        if len(Devices) == 0:
            Domoticz.Device(Name="PV Generation", Unit=1, Type=243, Subtype=29, Switchtype=4).Create()
            Domoticz.Device(Name="kWh total", Unit=2, TypeName="Custom", Options={"Custom": "1;kWh"}).Create()
            Domoticz.Device(Name="AC Voltage", Unit=3, TypeName="Voltage").Create()
            Domoticz.Device(Name="AC Current", Unit=4, TypeName="Current (Single)").Create()
        if len(Devices) == 2:
        DumpConfigToLog()
        self.baseUrl = "%s://%s/dyn" % (Parameters["Mode1"], Parameters["Address"])
        Domoticz.Debug("Base URL is set to %s" % self.baseUrl)
        self.login()
        Domoticz.Heartbeat(5)
    def onStop(self):
        Domoticz.Debug("onStop called")
        self.logout()
    def onHeartbeat(self):
        Domoticz.Debug("onHeartbeat called %d" % self.lastPolled)
        if self.lastPolled == 0:
            attempt = 1
            relogin = False
            while True:
                if attempt <= self.maxAttempts:
                    if attempt > 1:
                        Domoticz.Debug("Previous attempt failed, trying new login...")
                        relogin = True
                else:
                    Domoticz.Error("Failed to retrieve data from %s, cancelling..." % Parameters["Address"])
                    break
                attempt += 1
                sid = self.login(relogin)
                url = "%s/getValues.json?sid=%s" % (self.baseUrl, sid)
                payload = '{"destDev":[],"keys":["6400_00260100","6100_40263F00","6100_00464800","6100_40465300"]}'
                try:
                    j = r.json()
                    Domoticz.Log("No data from SMA inverter on %s; %s" % (Parameters["Address"], e))
                else:
                    Domoticz.Debug("Received data: %s" % j)
                    if "err" in j:
                        continue
                    result = list(j['result'].values())[0]
                    sma_pv_watt = result['6100_40263F00']['1'][0]['val']
                    sma_kwh_total = result['6400_00260100']['1'][0]['val']
                    sma_ac_volt = result['6100_00464800']['1'][0]['val']
                    sma_ac_current = result['6100_40465300']['1'][0]['val']
                    if sma_pv_watt is None:
                        sma_pv_watt = 0
                    if sma_ac_volt is None:
                        sma_ac_volt = 0
                    if sma_ac_current is None:
                        sma_ac_current = 0
                    if sma_kwh_total is None:
                        Domoticz.Log("Received data from %s, but values are None" % Parameters["Address"])
                        break
                    Devices[1].Update(nValue=0, sValue=str(sma_pv_watt)+";"+str(sma_kwh_total))
                    svalue = "%.2f" % (sma_kwh_total/1000)
                    Domoticz.Debug("kWh total: " + str(svalue))
                    Devices[2].Update(nValue=0, sValue=svalue)
                    svalue = "%.2f" % (sma_ac_volt/100)
                    Domoticz.Debug("AC Volt L1: " + str(svalue))
                    Devices[3].Update(nValue=0, sValue=svalue)
                    svalue = "%.2f" % (sma_ac_current/1000)
                    Domoticz.Debug("AC Current L1: " + str(svalue))
                    Devices[4].Update(nValue=0, sValue=svalue)
                    break
        self.lastPolled += 1
        self.lastPolled %= int(Parameters["Mode3"])
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
        Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
Posted: Friday 09 August 2024 11:59
by Bospieper
I have the same situation at my home, Two inverters. I will try your solution and let you know.
Regards Piet
Posted: Friday 09 August 2024 12:15
Perhaps also take a look at this one https://github.com/derenback/Domoticz-SMA-Inverter
Posted: Friday 09 August 2024 12:59
by Bospieper
After installing the plugin I have the following errors:
The used password is correct I checked by using ip and password to login
Posted: Friday 09 August 2024 13:25
by Bospieper
waltervl wrote: Friday 09 August 2024 12:15 Perhaps also take a look at this one https://github.com/derenback/Domoticz-SMA-Inverter
My first post was based on the plugin you suggested.
Grz. Piet
Posted: Saturday 17 August 2024 11:00
by mvveelen
Bospieper wrote: Friday 09 August 2024 12:59 Hi,
Did you try changing your password into something easier? And, are you sure you use the correct password (can you login with the credentials on the SMA directly)? Beware that you only login with the plugin and be logged off from the inverter itself.
Posted: Saturday 17 August 2024 14:37
by Bospieper
As I stated before I can login by using the ip of the sma and password.
Does this mean that I can't logon at the same time as the login from the sma app?
Grz Piet
Posted: Saturday 17 August 2024 15:25
by mvveelen
Bospieper wrote: Saturday 17 August 2024 14:37 Hi,
Grz Piet
Not sure, try?
Posted: Saturday 17 August 2024 15:44
by Bospieper
Both possible solutions don't work.
This is the reading of the status log:
Schermafbeelding 2024-08-17 status.png (14.69 KiB) Viewed 2299 times
and this of the problem log:
Schermafbeelding 2024-08-problem.png (21.67 KiB) Viewed 2299 times
Posted: Saturday 17 August 2024 16:48
by mvveelen
I have no idea what can be wrong, just for reference: you did everything that is in the README ?
# Domoticz-SMA-SunnyBoy
Domoticz plugin to get SMA Sunny Boy information
Tested with Python version 3.7 and 3.8, Domoticz versions 4.10717, 4.11799, 2020.1, 2020.2 and 2021.1
## Installation
Assuming that domoticz directory is installed in your home directory.
```bash
cd ~/domoticz/plugins
git clone https://github.com/rklomp/Domoticz-SMA-SunnyBoy
# restart domoticz:
sudo /etc/init.d/domoticz.sh restart
In the web UI, navigate to the Hardware page. In the hardware dropdown there will be an entry called "SMA Sunny Boy".
Make sure to (temporarily) enable 'Accept new Hardware Devices' in System Settings so that the plugin can add devices.
Please note you need python dev for the plugin to work To install Python Dev
```bash
sudo apt install python3-dev
## Known issues
## Updating
Like other plugins, in the Domoticz-SMA-SunnyBoy directory:
```bash
git pull
## Parameters
| Parameter | Value |
| **IP address** | IP of the SMA Sunny Boy eg. 192.168.1.231 |
| **Password** | password for the User Group, not the Installer one |
| **Query interval** | how often is data retrieved from the SMA |
| **Debug** | show debug logging |
## Acknowledgements
Based on the scripts found here
https://github.com/merlot-dev/Domoticz-SMA-SunnyBoy \
https://community.openhab.org/t/example ... r/50963/19
Wait, is web connect active on the SMA?
Scherm­afbeelding 2024-08-17 om 17.06.39.png (27 KiB) Viewed 2291 times
Posted: Sunday 18 August 2024 10:36
by Bospieper
This morning I did the whole installation again, I changed the password to a easier one. Unfortunately I'am getting the same errors again.
And yes the Webconnect is active on both SMA's
Grz. Piet
Posted: Sunday 18 August 2024 10:46
by Bospieper
I narrowd the problem now to one inverter. I have two, changing to the second one it immediately reads the solar data.
The difference between both is tat the one with the prolem is connecting by cable (speedwire) and the other is connection by WiFi
Posted: Sunday 18 August 2024 10:50
by mvveelen
Bospieper wrote: Sunday 18 August 2024 10:46 Hi,
Ah, and are the settings of both exactly the same? Webconnect? Other settings?
Oh, and which ones are they, because there might be a difference between the two I remember.
Edit:
I have one with HTTP and the other with HTTPS in the Domoticz settings. Try that, that was for me the solution !
Posted: Sunday 18 August 2024 11:38
by Bospieper
I have one inverter the SB2.5-1VL-40 and the other is a SB1.5-1VL-40
Changing te one with the error to https doesn't solve the problem.
Posted: Sunday 18 August 2024 11:42
by mvveelen
Hmmmm..... I've ran out of options then. This setting did the trick for me when I wasn't able to get both online. Will search in my old messages for any other suggestions, but I'm afraid this is it for me.
Posted: Sunday 18 August 2024 12:54
by Bospieper
I understand,thanx sofar. I know now that it is not the software (plugin) but probely some adjustment in the parameters of the inverter.
Again thanx.
Grz. Piet
Posted: Monday 19 August 2024 0:34
by solarboy
Have you considered the SBFspot plugin. I've found it to be exemplary with my SB 5.0 40.
