dzVents, update svalue only and do not update the device description
Posted: Monday 29 July 2024 12:44
by averter
I'm trying to use the dombusEVSE to charge my electric vehicle in solar mode. The mode requires that a grid power device svalue is updated to keep track of how much power can be used to charge the EV, and I am using a dzvents script to feed this value to the device. The main problem is that as I update the svalue using the `setValues`function (see
https://www.domoticz.com/wiki/DzVents:_ ... ll_devices) the function also updates the device description, and that forces the dombus plugin to send a new configuration to the dombus EVSE module (and it ends up never starting to charge the EV). So the question is if there is a dzvents function which updates the svalues only and leaves the device description untouched?
A MWE of the dzvents script is shown below
active = true,
devices = {
'Solax - Grid Power',
'Solax - Battery Power',
local GP = domoticz.devices('Solax - Grid Power') -- Power from/to grid
local BP = domoticz.devices('Solax - Battery Power') -- Battery charge
local EVSEGRIDMETER = domoticz.devices('dombus - (1.c) Grid Power') -- EVSE device
EVSEGRIDMETER.setValues(0,tostring(-GP.actualWatt - BP.actualWatt)..';0')
and the relevant portion of the dombus log is shown below
2024-07-29 11:33:02.565 dombus: onDeviceModified: device description=ID=1.c,CUSTOM,TypeName=kWh
2024-07-29 11:33:02.565 dombus: DEBUG:Parse Description field for device 1.c
2024-07-29 11:33:02.565 dombus: DEBUG:opt=ID=1.c
2024-07-29 11:33:02.565 dombus: DEBUG:opt=CUSTOM
2024-07-29 11:33:02.565 dombus: DEBUG:opt=CUSTOM setType=2147483648 typeName=Switch
2024-07-29 11:33:02.565 dombus: DEBUG:opt=TypeName=kWh
2024-07-29 11:33:02.566 dombus: INFO: Config device 0x1: type=0x80000000 typeName=kWh Options={'EnergyMeterMode': '1', 'SignedWatt': '1'}
2024-07-29 11:33:02.566 dombus: INFO: TypeName='kWh', nValue=0, sValue='-4499.858;-6.2175', Description='ID=1.c,CUSTOM,TypeName=kWh', Options={'EnergyMeterMode': '1', 'SignedWatt': '1'}
2024-07-29 11:33:02.578 dombus: DUMP: TX frame: P:2 3a 0000 -> 0001 12 DCMDCFG 0c 00 | CFG 0c 80 00 00 00 00 00 00 | c4
2024-07-29 11:33:02.678 dombus: DUMP: RX frame: P:2 3a 0001 -> 0000 03 A-CFG 0c 80 | d3
2024-07-29 11:33:04.080 dombus: DUMP: TX frame: P:2 3a 0000 -> 0001 03 DCMDCFG 0c 00 | 2b
Note the line `dombus: DEBUG:Parse Description field for device 1.c` which indicates the root cause of the problem.
Re: dzVents, update svalue only and do not update the device description
Posted: Monday 29 July 2024 12:47
by waltervl
Better ask the plugin author why the plugin updates the description also.... So the plugin does something strange and the you have to modify the dvents normal way?
But just using dzvents updateEnergy() function should also work.
Posted: Monday 29 July 2024 13:27
by averter
waltervl wrote: Monday 29 July 2024 12:47
That is what I've tried before the setValues function: using the updateElectricity function. updateEnergy does not work, so it is probably not suited for this type of device. None of these solutions work.
I've asked this question to the plugin's author, but he's more familiar with lua than dzvents (hence why I decided to post the question to the community).
For reference, I'm putting below a MWE in lua, created by the plugin's author, which works/does not update the description field of the device. I'm not using such script because 1) I want it to be in dzvents, and 2) it's just a MWE, it does not actually correspond to the power that I want to send to the device. The key issue is the updating process of the device, which works as intended with the below script but not with the one that I've shown previously.
GRIDMETERS={"Solax - Grid Power", "Solax - Battery Power"} -- List of meters which power should be summed (1 or more meters can be specified)
EVSEGRIDMETER="dombus - (1.c) Grid Power" -- Name of the virtual device on DomBusEVSE
commandArray={}
function getPowerValue(devValue)
-- extract the power value from string "POWER;ENERGY...."
for str in devValue:gmatch("[^;]+") do
return tonumber(str)
-- scan the list of devices that has changed
for devName,devValue in pairs(devicechanged) do
for j,name in pairs(GRIDMETERS) do
-- print("devName="..devName.." name="..name)
if (devName == name) then
-- one of the GRIDMETERS value has changed
totalPower=0
for k,meter in pairs(GRIDMETERS) do
-- print(otherdevices_lastupdate[meter])
totalPower=totalPower + getPowerValue(otherdevices[meter])
-- print("totalPower="..totalPower)
commandArray[EVSEGRIDMETER]=tostring(totalPower)..';0'
Posted: Monday 29 July 2024 15:08
by waltervl
What kind of device is it? See menu Setup - Devices
Then check what the appropriate update command is in dzvents wiki.
Also it seems that neither Set commands should change the description too. So something is strange here.
Posted: Monday 29 July 2024 15:17
by averter
waltervl wrote: Monday 29 July 2024 15:08
I agree that it is strange. The device is shown in the figure, general kWh, and so updateElectricity ought to work?
Posted: Monday 29 July 2024 15:38
by waltervl
Yes indeed, updateElectricity(power, energy) should work and not change the description.
What is the description being modified in? Is it being emptied or changed into something else?
Posted: Monday 29 July 2024 17:19
by averter
waltervl wrote: Monday 29 July 2024 15:38
According to the above log and what I see in the actual device is "ID=1.c,CUSTOM,TypeName=kWh"
Posted: Monday 29 July 2024 20:01
by waltervl
So what is the description of you update the power values with dzvents?
Posted: Tuesday 30 July 2024 7:36
by averter
waltervl wrote: Monday 29 July 2024 20:01
Everything indicates that updateEnergy is
updating the description of the device although it does not actually
changes its contents: the creator of the plugin confirms that 1) this is what is happening based on the log that is shown above, and 2) "ID=1.c,CUSTOM,TypeName=kWh" is the description that came originally with the device (I'm exchanging emails with him).
Could it be that these updating commands from dzvents read and feedthrough all the other fields than the actual power value (description, nvalue/svalue, etc.) during the update process?
Posted: Tuesday 30 July 2024 7:50
by waltervl
That could well be. But if the description does not change, what is the problem?
Posted: Tuesday 30 July 2024 8:37
by averter
waltervl wrote: Tuesday 30 July 2024 7:50
Note that I'm not overly familiar with the inner functioning of the plugin but, I know that some of its parameters need to be configured by editing the description of the devices and then saving them (example in figure below). What Paolo from Creasol said is that when the description is updated that forces the dombus plugin to constantly be sending a new configuration to the dombus EVSE module, and the end result is that the plugin ends up never starting to charge the EV when in solar mode. In other words, it seems that this problem triggers a constant restart of the EVSE module.
Posted: Tuesday 30 July 2024 9:01
by waltervl
You could try to add .silent() to the .updateElectricity() statement but I doubt it will help.
EVSEGRIDMETER.updateElectricity(-GP.actualWatt - BP.actualWatt,0).silent()
Else you have to use the lua script...
Posted: Tuesday 30 July 2024 9:14
by averter
Thanks for the suggestion and all your help. I've tested it just now, and unfortunately it doesn't work.
Guess it has to be done with lua, which is a bit disappointing, but oh well.
