updating percentage
Posted: Friday 19 July 2024 23:24
by tiga
hello...i am trying to update a virtual % device in lua but can not get it to work.
definitely couse of my lack of skills so hoping for your help
so i have a virtual percentage device setup called "wtw filter levensduur (9mnd)" idx = 10526
9 months = 9 x 30 x 24 = 6480 hours
i receive a filter counter called "itho filter teller" in hours
so this is one version i have tried:(of many unsuccessfull)
local itho_filter_teller        = tonumber(otherdevices_svalues['itho filter teller'])
if devicechanged['itho filter teller'] then
    percentage = itho_filter_teller / 6480
    commandArray['UpdateDevice']='10526|0|..percentage'
what do i need to change to get this working?
Re: updating percentage
Posted: Saturday 20 July 2024 8:33
by psubiaco
Try this:
    percentage = math.floor(tonumber(otherdevices_svalues['itho filter teller']) / 6480)
    print("Percentage="..percentage)
The only differences from your code are:
1. device is read only if needed
2. percentage value is converted to integer
3. percetnage value is printed in the LOG, so you can check that it is in a valid range
If it does not work, please copy here a piece of log
Posted: Saturday 20 July 2024 16:31
by tiga
thanks!
but this doesn't work
 2024-07-20 16:21:53.512 Status: LUA: Percentage=0
i got 0 on percentage
"itho filter teller" containes a value of 484 so percentage should be 484/6480= 0.07 %
i changed 6480 to 64.80 to make it full percentage value so percentage should give a value of 7
Posted: Saturday 20 July 2024 21:00
by tiga
dont know what went wrong the first time but now i get:
2024-07-20 20:58:22.118 Status: LUA: Percentage=7
but the % device does not get updated.....it stays at 0%
Posted: Saturday 20 July 2024 21:17
by tiga
solved by using this to update the device:
commandArray[#commandArray + 1] = { ['UpdateDevice'] = 10526 ..'|0|'..percentage }
Posted: Thursday 25 July 2024 16:51
by tiga
this is what i got now:
local wtw_filter_levensduur     = otherdevices_svalues["wtw filter levensduur (9mnd)"]
    percentage = math.floor(tonumber(otherdevices_svalues['itho filter teller']) / 64.80)
if wtw_filter_levensduur ~= percentage then
i only want "wtw filter levensduur (9mnd)" (idx 10526) to update only when it is needed.....
but with this script it gets updated every time 'itho filter teller' gets updated.
how can i fix that?
