How to check an osCommand in dzVents
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Hello to all
I have a data-logger running and every 2 minutes i take a copy of the memory contents. This IP-address is dynamic and there is no room to make it a fixe IP-address. Sometimes the data-logger receives a new IP-address in my LAN and then I don't notice this
The copy of the memory is done with the following line in a dzVents script.
domoticz.utils.osCommand('wget -nv -N -P /tmp/ 192.168.xxx.yyy/current/current_packets.vbus')
How can I check when this wget failed, because of a wrong IP-address
Greetings McMelloW
Re: How to check an osCommand in dzVents
Check the documentation on executeShellCommand()
It has option to check result (error code etc)
https://www.domoticz.com/wiki/DzVents:_ ... tion_3.1.0
McMelloW
Post by McMelloW »
waltervl wrote: Monday 08 July 2024 22:53 Check the documentation on executeShellCommand()
Thanks, I will dig into this example.
Greetings McMelloW
Kedi
Domoticz version: latest
Post by Kedi »
Most routers have the possibility to assign an IP-address to a MAC-address.
Is that a possibility?
McMelloW
Post by McMelloW »
Kedi wrote: Tuesday 09 July 2024 16:44 Most routers have the possibility to assign an IP-address to a MAC-address.
My router can only 10 fixed IP-addresses. So I have to make a choice.
Greetings McMelloW
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Is it possible to make data-logger send some data to domoticz?
McMelloW
Post by McMelloW »
habahabahaba wrote: Thursday 11 July 2024 16:36 Is it possible to make data-logger send some data to domoticz?
No this data logger does not send any thing. You have to get it
Greetings McMelloW
