Domoticz version 2024.7 released
Moderator: remb0
- Domoticz version: 2024.6
Re: Domoticz version 2024.7 released
Small issue with this version. In the last version my "Floorplan" would not update in Firefox after the laptop had been asleep without a manual refresh. Now in this version, for the first time, the log page also displays this behaviour.
I found the previous behaviour more useful. Perhaps just a small thing has been overlooked.
Otherwise a great rock solid release.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
- gizmocuz
The log page is not displayed without a reason.
Maybe the browser removed the cookie, or you did not enable 'remember me'
'a' solution could be to add the IP address of the laptop in the trusted network so you won't need a username/password
I assume Domoticz is used natively and not behind a (reverse) proxy?
Yes, Domoticz is on the same network and the IP is within the trusted zone. Firefox will connect using https but Edge would only connect with http (I have "Allow basic auto" enabled) and both Edge and Chrome shows a "not secure" warning to the left of the address bar.
All was fine on the previous stable and I obviously cleared cookies and site data.
- Domoticz version: 2024.4
When i try to download 2024.7.16140 for windows McAfee finds a threat and place the file in quarantine. Is there a solution to this so I can download the latest version. tried on several computer but all have McAfee on it and won't save the file
groet Jan
groet Jan
praet mar frysk
Who is the boss? You or McAfee? Just disable the scanner for a short time: https://www.wikihow.com/Disable-McAfee
- elzorrovega
- Domoticz version: 2024.7
Hello All,
In release notes Domoticz version 2024.7 I saw that Google Cloud Messaging was fixed. I use an iPhone with latest Domoticz iOS application (Client Ver 0.1.55) for which there has not been an update in years.
In the past, GCM (FCM) notifications worked properly with the possibility to choose which mobile device received the message. Later when I encountered notification issues with GCM, I switched over to Pushover.
In Domoticz settings and setup, GCM Notification are enabled and Mobile setup page show iPhone.
Whenever I use test buttons or DzVents to issue GCM messages, following errors appear in the log.
Is this feature available only for Android phones?
2024-09-08 17:59:47.674 Status: Notification: Domoticz test
2024-09-08 17:59:48.211 Error: FCM: Could not send message! Errorcode 401 (Auth error from APNS or Web Push Service)
2024-09-08 17:59:48.560 Error: FCM: Could not send message! Errorcode 401 (Auth error from APNS or Web Push Service)
2024-09-08 17:59:48.560 Notification sent (fcm) => Failed
2024-09-08 17:59:48.562 Active notification Subsystems: browser, email, fcm, pushover (4/13)
2024-09-08 18:00:06.713 Status: Notification: Domoticz test
2024-09-08 18:00:07.073 Error: FCM: Could not send message! Errorcode 401 (Auth error from APNS or Web Push Service)
2024-09-08 18:00:07.073 Notification sent (fcm) => Failed
2024-09-08 18:00:07.076 Active notification Subsystems: browser, email, fcm, pushover (4/13)
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bullseye -64 bit OS 6.1.21-v8+ #1642
Domoticz Version: 2024.7
zwave-js-ui: 9.9.0.09b107a
zwave-js: 12.4.4 home id: 3714679688 home hex: 0xdd698388
- Domoticz version: 2020.2
Hi every body!
Can you confirm that with this last version, Gpio system ( old or newest) is fixed?
I use 6 GPIO (4 OUT for relay and 2 IN) I dont want change that ( but i can change the number of port in configuration files)
I have the 2023.2 domoticz version.
I would have the last version in order to use the new version of PV widget!
Thanks you very munch!!
Rpi Master 2022.2 Beta 14905 (Broadlink ok.....)
Rpi slave 2020.2 (since 10days but with error...) with 2 rflink(rts 433 + 833)
GPIO system did not change, only on newer OS'-es the Linux GPIO system has changed and there is a fix for that. I have no idea if this really works.
But as long as you do not upgrade your OS Domoticz new versions will still use the old way of working.
will there be any support of the sungrow inverter?
Posting the request here willl not get it in Domoticz. If you are not able te create it yourself you will have to wait until someone shares it's integration. Perhaps look here https://github.com/MickMake/GoSunGrow/ for some integration. mQTT seems promising of it uses MQTT Autodiscover.
But create another topic as this is definitely not the correct topic to discuss this.
thanks i will do that.
anyone have this version on it with this Raspberry Pi OS 2024-10-22 together with domoticz 2024.7
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
- FireWizard
What do you mean with "this version"?
The Raspberry Pi OS from 2024-10-22 is just the latest version of Bookworm with all updates installed until that date.
Yes, Domoticz 2024.7 runs on that version of Raspberry Pi OS.
But, what is your issue or question?
no problem, just wanted to know if the pi could update without any problems
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
Closing this topic. If you have questions about 2024.7 start a new topic in an appropriate sub forum.
