Domoticz version 2024.7 released
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
Moderator: remb0
gizmocuz
Post by gizmocuz »
It's time again for a new stable release!
This could not have happened without the help of everyone who contributed to make this happen!
Forum moderators, users, beta testers and specially all those who contributed with code! Thank you once again!!!
As always, PLEASE make a FULL backup of your Domoticz folder (or in case of an embedded system, your SD card!)
This way you can always return to the previous version you were running before this update!
Thanks to all volunteers who helped with the implementation! I know it was a lot of work with a lot of stress!
A few notes before updating:
  • Because some users are still experiencing migration issues to ZWaveJS-UI, OpenZWave is back (No support!).
    The OpenZWave project was stopped 2 years ago.
    We still urge ysers using OpenZWave to migrate to ZWaveJS-UI in combination with the MQTT Autodiscovery method build into Domoticz.
    (See https://www.domoticz.com/wiki/Zwave-JS-UI)
  • Armv6 device support has been stopped. Sure, you can still build Domoticz yourself, but no binary versions are published anymore.
    This means devices like the Raspberry Pi 1, Pi Zero from ~12 years ago are not supported anymore.
  • When using Domoticz with client/server setup (multiple locations), it is important that both server and client run this version or a beta.
  • Support for remote updating a RFXCom transceiver has been removed as it was not working 100% with the latest models.
    This was a joined decision between us, and you now need to use the flash application from the RFXCom website.
Here are the most important changes (there are way too many changes to list them all):
Version 2024.7 (July 13th 2024)
- Implemented: P1 Meter, Report, Header now also supports simple mode (No T1/T2/R1/R2 but just total)
- Fixed: Google Cloud Messaging (GCM/FCM) possible crash when notification needed to be send
Version 2024.6 (July 8th 2024)
- Fixed: EventSystem, LOG_FORCE now always logged
- Changed: Google Cloud Messaging (GCM) now uses the new v1 API of Google's Firebase Cloud Messaging (FCM)
Version 2024.5 (July 7th 2024)
- Implemented: Currency Symbol in Location Settings
- Implemented: dzVents, Added historical data helper 'med' to calculate the median value
- Implemented: dzVents, Improved logging
- Implemented: Energy Dashboard
- Implemented: Enever, Added Budget Energy and Eneco
- Implemented: Enphase, Live storage data
- Implemented: Enphase, Option for more Inverter details (ac/dc voltage, temperature, lastupdate)
- Implemented: Event Editor, Close/Close All menu dropdown
- Implemented: Event Editor, Storing/Loading opened events
- Implemented: Hour chart for P1 log
- Implemented: MQTT-AD Climate Fan Mode
- Implemented: MQTT-AD Climate Swing Mode
- Implemented: OpenWeatherMap, API 3.0 support
- Implemented: P1 Meter, option to specify view (low/high tariff or simple (dynamic contract))
- Implemented: Possible to query a range of device states via JSON
- Implemented: SolarEdge, polling Storage devices
- Fixed: Data Pushers, Forecast for Weather Station subtypes
- Fixed: Floorplan, better detection of switches
- Fixed: Hardware Setup, hiding extra parameters when selecting a python plugin
- Fixed: PythonEx framework, two notifications where send for switch type devices
- Fixed: Python framework, custom image loading
- Removed: Cereal Proxy (not used anymore)
- Changed: EvoHome, now making use of general logging system
- Changed: MQTT-AD, now also handles brightness scale number values as string
- Changed: SBFSpot, disabled error 28 error
- Changed: Selector switch now displays correct state in Data field (and devices overview)
For a full detailed overview visit:
https://github.com/domoticz/domoticz/commits/master/
https://github.com/domoticz/domoticz/bl ... istory.txt
You can also update manually by going to your Domoticz folder and issue the following command: ./updaterelease
Up up and away :mrgreen: !
keros
Re: Domoticz version 2024.5 released
Post by keros »
Thank you gizmocuz and everybody for all the work accomplished !!
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
Kedi
Post by Kedi »
Nice work. :)
But I am missing some info.
This is not very informative.
Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Continues here: https://www.domoticz.com/forum/viewtopic.php?t=42497
Herman-H
Post by Herman-H »
thanks for all the work, Top.
gizmocuz
Post by gizmocuz »
Kedi wrote: Sunday 07 July 2024 9:37 Nice work. :)
Create a new Forum topic for this, so this topic stays clean... Just post a link here to your new topic for reference
Edit: Post can be found here: https://www.domoticz.com/forum/viewtopic.php?p=318301
madpatrick
Domoticz version: 2024.7
Post by madpatrick »
Update executed over 2024.4 and looks fine
Thanks Team Domoticz !!
-= HP server GEN8 Xeon(R) E3-1220L_V2 -=- OZW -=- Toon2 (rooted) -=- Domoticz v2024.7 -=- Dashticz v3.12b on Tab8" =-
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Well done, Domoticz team. 👍👍👍
Update went like charm and it all works OK. 🥂🍾
Greetings McMelloW
sirus
Domoticz version: 2.2286
Post by sirus »
The Energy board is soooo cool !
Great thanks for this Update -> I just did another well deserved donation for the work :mrgreen:
Thanks all for the great work :=)
Raspberry / Domoticz / RFXtrx433E / multiple home made devises
My blog for domoticz / electronics stuff : domotique.web2diz.net
akamming
Re: Domoticz version 2024.6 released
Post by akamming »
tx gizmocuz and all other developers for the new release. I just updated without issues.
I do have a question, in the changelog i read:
how can i use this feature: the IOS app just crashes and hasn't been updated in 3 yrs, so how can i use the GCM/FCM feature? Is this documentated somewhere?
Another great improvement is that Domoticz now uses the (dynamic) energy prices in the database to calculate the energy costs.
https://www.domoticz.com/wiki/Applicati ... alculation
WouterO
Post by WouterO »
Hi, thanks for this release, the update on my RPi 4 using Domoticz’ update option was perfect.
I so love the Energy Dashboard!
One silly question: how can I get a direct link to the Energy Dashboard on the main Domoticz Dashboard? I can’t ‘favorite’ the Energy Dashboard, can I?
Xenomes
Post by Xenomes »
Congratulations with the new release!
HP T630 (32GB SSD/8GB Mem) - Ubuntu 22.04.4 LTS (64Bit) - Domoticz 2024.7 with Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
rick8245
Post by rick8245 »
It does not work on my Raspberry at all.
It is unreachable, nothing works if the GUI comes up sometimes
Am I the only one ? and any ideas about this??
I already cleaned up the browser history
Is there a way to get back to the previous version??
Thanks in advance
Rick8245
Jeetje
Post by Jeetje »
rick8245 wrote: Tuesday 09 July 2024 8:54 It does not work on my Raspberry at all.
Thanks in advance
Rick8245
Also freezes after a few hours overhere.
I have to do:
sudo service domoticz.sh restart
after a while
jvdz
Domoticz version: 4.107
Post by jvdz »
"Doesn't work" post aren't going to get you any resolution.
Create a new topic in the correct forum with the appropriate info: https://www.domoticz.com/wiki/Troubleshooting
rick8245
Post by rick8245 »
@jeetje,
I do use that as a workaround too (thanks for that)
I restart it every hour at this moment and that works OK.
Hopefully there will be a structural solution the next weeks.
Rick8245
rick8245 wrote: Wednesday 10 July 2024 7:52 @jeetje,
Rick8245
This is not the topic to discuss this and it will not be solved until more is clear what is going on. Please make a more complete issue in the bugs and problems topic https://www.domoticz.com/forum/viewforum.php?f=6
Also check the troubleshooting wiki https://www.domoticz.com/wiki/Troubleshooting
janpep
Post by janpep »
jvdz wrote: Tuesday 09 July 2024 17:34 "Doesn't work" post aren't going to get you any resolution.
But it is the most logical place to mention it here!
Here people also report what is so nice about it and that it went well.
But that apparently does not apply to everyone. That can (regarding the release) be a very usefull warning to others. May be to wait until clear what the cause and/or solution is.
(Next to that, you might open a new topic to discuss the details.)
In addition: Maybe it's up to a moderator to give the clues on this and not each individual member with their own thoughts about it.
Domoticz in Ubuntu virtual machine on Synology DS718+ behind FRITZ!Box.
Using: EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
domovincent
Domoticz version: 14285
Github page
Post by domovincent »
Thanks for this release. It looks like a very nice update indeed.
One question about the release process though; are github releases supported by the project, or not? Or is something broken in the pipeline?
I noticed the latest release is not there.
(reason is that I install updates automatically on my raspberries, using ansible, from the github page)
gizmocuz
Re: Github page
Post by gizmocuz »
domovincent wrote: Wednesday 10 July 2024 11:24 One question about the release process though; are github releases supported by the project, or not? Or is something broken in the pipeline?
Thanks for reporting, release tag made for 2024.6
Locked
