Page 1 of 2
Implant, Closing gate by hand timer reset
Posted: Friday 05 July 2024 14:50
by PeterRozenveld
I have an Implant and a sectional door,
At the door through a relay I control the implant. That works.
Domoticz gives a good display.
I just want domoticz to give a pulse, when the door is open longer than 30 minutes. However, the door only knows since it has a bistable function, that with each pulse the door then opens, then closes. Do I close the door by hand. Then the counter of Blockly continues to run and still sends a pulse , causing the door to open again. How do I stop that counter , and reset that command: If "door" is "Open" THEN CLOSE_SWITCH after 1800 seconds.
Translated with DeepL.com (free version)
Re: Implant, Closing gate by hand timer reset
Posted: Friday 05 July 2024 16:55
You will need a door sensor that sends the state of the door to Domoticz. Then you know the state of the sectional door (open/close). Else it will be guessing what the state of the door is.
Posted: Saturday 06 July 2024 3:39
by PeterRozenveld
"At the door, I control the implant through a relay. That works.
Domoticz gives a good display. "
That's what I meant by the input on the first input. The signaling what the state of the door is. Open or closed. The 2nd OUT , that's what I control the Novoferm4 with. That responds to a Pulse, one time it closes, the next time it opens.
Posted: Saturday 06 July 2024 10:24
Ah, in blockly you cannot (I believe).In dzvents you have the cancelQueuedCommands() function for this.
Posted: Saturday 06 July 2024 10:59
by PeterRozenveld
Ok, that's what I thought. I notice you know more about it than I do. So now get someone to find, who could possibly write this....
Posted: Saturday 06 July 2024 12:52
What does your blockly script look like? Probably easy to convert it into dzVents....
Posted: Saturday 06 July 2024 13:49
by PeterRozenveld
Where shall I start, have tried to make some in the 3 phases, they all fail. The simplest thing would be if the counter reset itself upon reaching the final contact : Door closed. And that it continues , when e.g. after 40 seconds the door is still not closed. The problem is namely that bistable state , which is caused by a pulse pusher. Too bad that novferm4 has no Up and Down pusher / pulse.
I will start with the last 2, man what a mess:
Posted: Saturday 06 July 2024 23:21
I did it a liitle differently: When my garagedoor is open for X minutes I get a warning. Instead of a warning you can close the door.
The script is checking every 10 minutes if the door is still open.if more than 20 minutes open then the switch is triggered.
Replace 'YourDoorSensor and YourDoorSwitch with your own devices.
		timer = {'every 10 minutes'},
	execute = function(domoticz)
	    local garage = domoticz.devices('YourDoorSensor') --  doorsensor
            local garageswitch = domoticz.devices('YourDoorSwitch') --  doorswitch
           -- garage sensor check
           if garage.state == 'Open' and garage.lastUpdate.minutesAgo > 20 then
               -- domoticz.notify('','garagedeur staat meer dan 20 min open!')
               garageswitch.SwitchOn()  -- Switch to close the door
               domoticz.log('door closed', domoticz.LOG_INFO)
Posted: Sunday 07 July 2024 10:34
by PeterRozenveld
Thank you!!! Can you explain what does what ?
After all, trying to understand some of it so I know what is happening.
Posted: Sunday 07 July 2024 11:03
As already explained the script is checking every 10 minutes
timer = 10 minutes
if the garagedoor is open and longer than 20 minutes
If not do nothing if true then switch the garage door switch
and put a log statement
everything with prefix -- is treated as a comment/remark, so not executed.
See also the extensive wiki: https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Posted: Sunday 07 July 2024 13:34
by PeterRozenveld
		timer = {'every 2 minutes'},
	    local garage = domoticz.devices('Sect.Stand-deur(1)') --  deur informatie relais K6 Phoenix
            local garageswitch = domoticz.devices('Sect.Novoferm-f(2)') --  de aansturing vd Novoferm4 op contact f
           -- garage sensor check kijken of de deur open is
           if garage.state == 'Open' and garage.lastUpdate.minutesAgo > 3 then
               domoticz.notify('','garagedeur staat meer dan 10 min open!')
               garageswitch.switchOn() -- stuurt de Novoferm4
## doesn´t seem to be right, The switch doesn´t go on.
## and the switch must be a puls !
Posted: Sunday 07 July 2024 13:38
What type of Domoticz device is 'Sect.Novoferm-f(2)'?
See the device list in menu setup - devices
Posted: Sunday 07 July 2024 13:53
by PeterRozenveld
That's an electronic device Novoferm4 for moving the door, When you close the 2wires of the f-connection , the gate will close-stop-open-stop
The last state will be remembered , so if the last state was open-then stopped, the next move will be close!
So it need puls of 0 Ohm , ( Or Puls of 180 Ohm for ventilation = small opening)
Posted: Sunday 07 July 2024 17:32
I need the device type in Domoticz, see menu setup - devices or on the device widget.
Posted: Sunday 07 July 2024 18:16
by PeterRozenveld
The device type is now an normal On/Off switch...
I think is should be kind a sort of push ? I Can´t find a good type by this real device "Novoform-4"
Posted: Sunday 07 July 2024 19:05
How is this device "Novoform-4" connected to Domoticz? What Hardware gateway is used (python plugin?)?
Does it work when you click on the switch from Domoticz? I assumed it worked already from Domoticz otherwise it has no use to created a script with it.
Posted: Tuesday 09 July 2024 7:47
by PeterRozenveld
It is a Fibaro "Smart Implant" :
https://manuals.fibaro.com/smart-implant/
¨SwitchImplant 1" (The Input) is connected to a relay that tells if the door is closed or open. (Hangs the input to ground)
"SwitchImplant 2" I use as Output, which should activate the via a Pulse the Novoferm4-Contacts-"F" to start moving.
https://www.novoferm.nl/fileadmin/user_ ... -50_01.pdf
The only thing you cannot influence is : which direction/ or that it stops !
When it closed last time, it will open at a pulse (at least if it is stationary). and Vise Versa. When it moves, and gets a pulse, it stops ! So we have to do Fuzzy logic method: Every 20 seconds, for example, give a pulse until the signal comes : Door Closed! ( Run time door is 16 seconds)
Note , I am already very grateful to you for the effort you put into it !!!
And I had a ¨pressive day¨ yesterday .
You see, I have Functional Neurological Disorder, which is when you don't take burnout seriously.
Posted: Tuesday 09 July 2024 8:18
by PeterRozenveld
This works, but garageswitch should be a puls ! (ON _OFF)
Posted: Tuesday 09 July 2024 13:28
Perhaps something you can set on the Zwave implant device itself?
Edit: See page 14 (section 4.9) of the manual (Connection with gate opener)
Posted: Tuesday 09 July 2024 14:35
by PeterRozenveld
No, not possible ! Must be een puls, because other buttons, (push) activate the same way ! The Implant is not the only activator.
