Billing Period for electricity consumption & cost per day, month and year
Posted: Friday 21 June 2024 15:45
by McMelloW
Hi to all,
As far as I understand, this script uses the calendar year as the period. As anybody changed this to the Energy Billing period. If so can you tell me how?
In my opinion it is more logic to see the usage and cost during the billing period instead of the calendar period.
Re: Billing Period for electricity consumption & cost per day, month and year
Posted: Friday 21 June 2024 18:36
You mean this script I suppose
viewtopic.php?t=33066
I have a script running to get my gas consumption from a specific day (the day my gas tank was filled up again)
I use a, so it seems, undocumented option of the graph API call for counters that uses a range from date to date: &range=YYYY-MM-DDTYYYY-MM-DD
Notice the "T" between the dates.... (Edit: It is documented now...)
The json should look something like this to get data from 20 januari to today:
/json.htm?type=command¶m=graph&sensor=counter&idx=513&range=2024-01-20T2024-06-021"
I use a function to get the data:
local function triggerJSON(idx,from,to)
local URLString = dz.settings['Domoticz url'] ..
"/json.htm?type=command¶m=graph&sensor=counter&idx=" .. idx ..
"&range=" .. from .. "T" .. to
dz.openURL({ url = URLString,
method = "GET",
callback = "history" })
I put the last tank date in a user variable that I can change easily withot changing the script. Get that date and trigger the jsaon call from tan date to today.
local LastTankDate = dz.variables('LastTankDate').value
local dateFormat = "!%Y-%m-%d"
triggerJSON(myDevice, LastTankDate, os.date(dateFormat))
Posted: Friday 21 June 2024 19:52
by McMelloW
waltervl wrote: Friday 21 June 2024 18:36
https://www.domoticz.com/forum/viewtopic.php?t=33066
Thanks for your reply. Yes it is the script of that topic. I found this on wiki API/JSON page. It all looks a but complicated to me, but I will dig into it and see or it brings me to a solution.
