accept new hardware - Prevent creating MQTT AD devices
Posted: Wednesday 12 June 2024 17:22
by JuanUil
Hi Folks,
So I am on the latest beta and zwave-js.
A lot of new, mostly irrelevant, devices appear.
When I remove them I constantly get the message that accept new hardware is disabled.
When I let them be accepted as new devices and put them as not being used they are still questioned which sometimes slows down my response.
Is there a way to get rid of these devices permanently?
Jan
Re: accept new hardware
Posted: Thursday 13 June 2024 0:16
by waltervl
I believe there is an option in Zwave-JS-UI somewhere to not publish those unwanted device to MQTT and then they won't appear in Domoticz.
Posted: Thursday 13 June 2024 10:57
by JuanUil
waltervl wrote: Thursday 13 June 2024 0:16 I believe there is an option in Zwave-JS-UI somewhere to not publish those unwanted device to MQTT and then they won't appear in Domoticz.
Hi Walter,
question is then where to find it.
Posted: Thursday 13 June 2024 11:45
by waltervl
Posted: Thursday 13 June 2024 13:26
by JuanUil
Hi Walter,
Not working
see below my settings in zwavejs-ui and the report in the log
Settings:
Log:
2024-06-13 13:14:50.652 MQTT: Accept new hardware disabled. Ignoring new sensor Achterkamer-Verlichting Achter (Achterkamer-Verlichting Achter_electric_kwh_value)
Re: accept new hardware - Prevent creating MQTT AD devices
Posted: Thursday 13 June 2024 13:43
by gizmocuz
Okey, but find the Watt/kWh not important?
If you go to the devices overview, you can set them unused, and they won't show up in the utility tab
Posted: Thursday 13 June 2024 14:26
by JuanUil
gizmocuz wrote: Thursday 13 June 2024 13:43 Okey, but find the Watt/kWh not important?
That is correct they don't show up but are still interviewed altough I have set them to disabled in Zwavejs-ui and set them to unused in the devices overview
Posted: Thursday 13 June 2024 15:07
by waltervl
You probably still have retained MQTT config topics in your MQTT broker. https://www.domoticz.com/wiki/MQTT#Dele ... ined_topic
Posted: Thursday 13 June 2024 15:38
by JuanUil
Deleted all messages but problem remains :(
Posted: Thursday 13 June 2024 16:15
by waltervl
And restart the Domoticz MQTT AD hardware gateway (press on update button) or restart Domoticz completely as indicated in the wiki section I referred to.
Are those not needed MQTT AD config topics gone or recreated by zwave-js-ui?
Posted: Thursday 13 June 2024 19:31
by JuanUil
That did the trick!!
Restartet the broker and all well now, no more interviewing.
Thnx for the help!!
