meaning pi-sensor HDD /
BartSr
Domoticz version: V2024.3
Post by BartSr »
Hi !
I have all pi-sensors active
HDD/ shows almost 100%. Feels like being not OK
What to do? It seems there's plenty space on the SD-card
-Bart
raspberry Schermafbeelding 2024-06-11 221308.jpg (14.46 KiB) Viewed 724 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
FireWizard
Re: meaning pi-sensor HDD /
Post by FireWizard »
What does
df -h
show
BartSr
Post by BartSr »
This is the screenshot. Seems not OK. How can I save storage place?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
FireWizard
Hi @BartSr
Try to find the largest file.
See: https://www.cyberciti.biz/faq/linux-fin ... g-find-du/
or to find the 20th largest files, execute the following command.
sudo du -aBm / 2>/dev/null | sort -nr | head -n 20
Perhaps you can remove or move the largest files
Kedi
Post by Kedi »
After you cleaned up you could also set a notification on the 'HDD /' widget to get an early warning if usage is over a certain percentage.
HvdW
Domoticz version: 2023.2
Post by HvdW »
Using
sudo tree --du -h | grep M] | awk '{print NR, $0}'
you can browse the contents.
Without the grep it displays everything.
Change the grep to K] to show smaller files and G] to find huge files, amongst which maybe the domoticz directory.
Oh, BTW do a cd / to display the contents starting from the root directory.
If the result is too much for an overview try
sudo tree -L 3 --du -h | grep M] | awk '{print NR, $0}'
Bugs bug me.
