Set value of Dimmer without turning the switch on  [Solved]
lnrdnl
Domoticz version: 2024.4
Post by lnrdnl »
Does anybody know if it is possible to set the level of a dimmer without switching the device on?
It seems properties of the dimmer (or switch) object in DzVents are readonly. So the only possible way to mutate them is by using the corresponding methods. So this does not work:
dimmer.level = 20
This does:
dimmer.setLevel(20)
dimmer.dimTo(20)
I think mutating properties with methods is very convenient and good practice. BUT! I would like to set the level without switching the device on. The reason I want to do this is because I would like to keep the "switching" logic in one script. And the "value" logic in another (based on sensor values from lux sensors).
What I tried so far is:
dimmer.level = 20
dimmer.setLevel(20).silent()
dimmer.dimTo(30).afterSec(4)
dimmer.cancelQueuedCommands()
Any ideas? Thanks in advance!
Re: Set value of Dimmer without turning the switch on
It is the same with the normal user interface. As soon as you change the dimmer setting the device will switch on. So probably no way to override.
So you have to overthink your logic and merge the scripts....
lnrdnl
Re: Set value of Dimmer without turning the switch on  [Solved]
Post by lnrdnl »
I think it is not possible. I use Zigbee2MQTT to control the actual device and even there it is not possible.
So now I solved it by storing the LevelToSet as a Domoticz variable. From the "value" logic scripts I update the Domoticz variable. And in the "switching" scripts I use
dimmer.setLevel(domoticz.variables('LevelToSet').value)
Tradeoff is that I need a little more logic for switching on and off because I can't use
dimmer.toggleSwitch()
anymore.
Tukker
Domoticz version: 2023.2
Post by Tukker »
Let the value of the dimmer be read by another switch.
Bugs bug me.
Why not just have the lux sensor trigger the lights on/off including dimmer level?
I have a script like this running without issues.
lnrdnl
Post by lnrdnl »
waltervl wrote: Saturday 08 June 2024 0:31 Why not just have the lux sensor trigger the lights on/off including dimmer level?
Because for this specific light I want a motion sensor and a simple switch to trigger it (not auto switching). But I want the value based on the lux sensor. I could make a specific script for only this device, but I would rather keep the logic seperated. The way I solved it now is working perfectly. Case closed.
I now have the Lux sensor script reading and evaluating all lux sensors and switching dummies and setting the variable: LevelToSet.
Dummies:
IsLightInside
IsLightOutside
IsLightGarage
One script for handling all the motion sensors.
And one script for handling all the switches (including the dummies).
