Same Zigbee device detected differently on two Domoticz instances (Z4D)
Posted: Saturday 01 June 2024 11:37
by DebgBill
I have a strange issue I don't know how to fix. I have bought 4 identical Zigbee devices (TS011F-din) and plugged one pair into each of my two Domoticz instances.
On one of them they are recognized as simple switches, on the other (done with an earlier version 6 month ago) they are correctly identified as Switch/Power/Meter/Voltage
I tried re-associating the wrong ones after upgrading the plugin to the latest version.... same result.
Any idea? I suspect a regression in the latest version as it worked fine on the old one, and not on my newly reinstalled one.
Blaise
Re: Same Zigbee device detected differently on two Domoticz instances
Posted: Saturday 01 June 2024 13:16
by Thorgal789
Hello, wich one zigbee plugin ?
Posted: Saturday 01 June 2024 14:05
by DebgBill
I'm using https://github.com/zigbeefordomoticz/Domoticz-Zigbee, version May 2024 - stable7.1.012 ( 2024.04)
Blaise
Posted: Saturday 01 June 2024 15:06
You have to check the zigbee details of the devices. Could be that the tuya Manufacturing ID (eg _TZ3000_okaz9tjs) is different between the models. Also check in the zigbee4Domoticz UI if the new device is listed as certified.
Re: Same Zigbee device detected differently on two Domoticz instances (Z4D)
Posted: Thursday 06 June 2024 23:13
by DebgBill
The device is certified. I tried re appairing the units. Surprisignly one was then identified as TS011F-din and the other as TS011F. Both are DIN mounted. The one identified as DIN now has all the sensors, the other one is still seen as just a switch. Both are identified as _TZ3000_qeuvnohg
I've just received two more units.... I'll see how they behave.
Thanks for the hints anyway
Posted: Friday 07 June 2024 10:48
Perhaps report that to the zigbee4Domoticz certified devices repository, see below how to do that.
https://zigbeefordomoticz.github.io/wik ... evice.html
