How to disable port 6144
BarryT
Domoticz version: 2024.3
Post by BarryT »
how to disable the 6144 port sharing in domoticz trough the init.d?
I have:
DAEMON_ARGS="$DAEMON_ARGS -www 80"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 0"
This works great for port 80 and disables the https functionality wich i do not use, but i cant find an arg setting for the remote port.
i tried to fill in port 0 in the settings page, but its not persist after a reboot so it went back to 6144.
I ask this because i have another service running on port 6144 and this gives me a port conflict.
It is an pain in the ass to change the 6144 port of the other setting.
Thanks,
Barry
jvdz
Domoticz version: 4.107
Re: How to disable port 6144
Post by jvdz »
Did you try updating the port setting to 0? That afaik will disable the remote sharing.
BarryT
Post by BarryT »
jvdz wrote: Monday 27 May 2024 15:07 Did you try updating the port setting to 0? That afaik will disable the remote sharing.
Thanks Jos, i did but after reboot the port had changed back to 6144 and so was the conflict coming in..
jvdz
Post by jvdz »
Just tried on a test docker setup, and it indeed seems that when put to 0, the Domoticz restart restores the 6144 port.
So maybe set it to something high like 16144 to get rid of the conflict?
BarryT
Post by BarryT »
jvdz wrote: Monday 27 May 2024 16:08 Just tried on a test docker setup, and it indeed seems that when put to 0, the Domoticz restart restores the 6144 port.
I can try that, Thanks!
Anyway, i was hoping to disable the function completely..
janpep
Domoticz version: 2025.1
Post by janpep »
BarryT wrote: Monday 27 May 2024 17:04 Anyway, i was hoping to disable the function completely..
And otherwise your firewall will block it from outside traffic that you do not want?
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
