http command to shelly
paul402
Post by paul402 »
I can send these two commands successfully in the browser and via python.
http://192.168.2.41/rpc/Cover.Open?id=0
http://192.168.2.41/rpc/Cover.Close?id=0
but I have not been able to do in in dzVents.
The Wiki instructions I could not understand. Yes I'm probably not very clever.
Give me a hint please.
Re: http command to shelly
Search this forum for "dzvents shelly http" and you would have found somthing like topic https://www.domoticz.com/forum/viewtopi ... tp#p283937
Instead of using dzvents to open close a Shelly Cover you could also make a dummy Blinds device in Domoticz https://www.domoticz.com/wiki/Dummy_for ... l_Switches
Then put those 2 http commands as On Off action https://www.domoticz.com/wiki/Managing_ ... Off_Action
Tukker
Domoticz version: 2023.2
Post by Tukker »
- setup -> hardware -> dummy (create the possibility to create dummy devices)
- setup -> hardware -> dummy -> create virtual sensors choose switch
- use the switch and edit it http://192.168.2.21/relay/0?turn=on for on and http://192.168.2.21/relay/0?turn=off for off
- in dzvents choose this device by name or by number.
- read the dzvents wiki
Enjoy learning to program. It's great fun.
Bugs bug me.
paul402
Post by paul402 »
Thanks. Yes I have already been using python to send http commands from on/off actions but wanted to incorporate the functionality in Dzvents.
I now have another issue but I will post that seperately.
