control tasmota RGB GU10 bulb from wall switch
Posted: Wednesday 15 May 2024 19:52
by BurningTyre
I have a Tasmota GU10 RGBCW led bulb. (
https://www.athom.tech/blank-1/gu10-rgbcw)
It works perfectly with Domoticz, i can control the colors and turn it on/off.
But i want to control the colors from a wall switch. Is there any way to have a wall switch communicate with the bulb or to domoticz?
Re: control tasmota RGB GU10 bulb from wall switch
Posted: Sunday 19 May 2024 18:08
by PierreT
Sure. You can use e.g. a Klik-Aan-Klik-Uit transmitter to control a dummy device in Domoticz and then use on (dummy) device change scripting to send commands to the Tasmota device.
Posted: Tuesday 28 May 2024 15:37
by BurningTyre
Posted: Tuesday 28 May 2024 16:22
by BurningTyre
Or something like this, but then for EU wall socket
https://youtu.be/GERPRWChSQw?si=ten1UbeDbFnZx0-W
Posted: Friday 31 May 2024 12:27
by PierreT
Depends on the protocol it uses. It's not listed as a supported device by RFXCOM
I was thinking less fancy. Like a klik-aan-klik-uit wall mount switch and then program Domoticz to respond to signals as follows:
- click top for on, bottom for off
- hold top for increase brightness/colour, hold bottom for decrease
- if on, click top for toggle mode between brightness and colour
