dzvent sendtoURL to control switches on another Domoticz server
andrhrstv
Post by andrhrstv »
I used dzvent sendtoURL to control devices on another Domoticz server that I have, but because of the authentication changes in the recent versions of Domoticz I can't get my dzvents to authenticate to the API of the other Domoticz anymore.
The 2 Domoticz servers communicate thru public IPs.
I used to send the username and password as parameters in the URL, but that is now deprecated.
I tried "Allow Basic-Auth authentication over plain HTTP (API only)."
I have tried this now (as well as variation without the Basic, thru HTTP and HTPS as well):
		domoticz.openURL (
                url = 'https://DNS.name/json.htm?type=command&param=udevice&idx=66&nvalue=0',
                method = 'GET',
                headers = {
                  Authorization = "Basic <YWRRANDhOM4=:QrRANDOgfMTkw>"
So wanted to find out how anyone else had overcome this and what you are using.
Cheers
habahabahaba
Domoticz version: 2024.4
Re: dzvent sendtoURL to control switches on another Domoticz server
Post by habahabahaba »
what are Dz versions ?
Tukker
Domoticz version: 2023.2
Post by Tukker »
Try this:
https://www.domoticz.com/wiki/Setting_up_Device_sharing
Much easier.
Choose which sensors or switches wil apparaat in the other domoticz setup.
Bugs bug me.
According Domoticz API documentation the authorization header should contain one encoded string "username:password" You seem to have split it up into 2 strings.
When creating your own app or script this is not always done for you.
First the username and password are combined into one string "username:password"
This string is encoded using the RFC2045-MIME version of base64
The authorization method and a space i.e. "Basic " is then put before the encoded string.
This results in a header in the following format:
Authorization: Basic QWxhZGRpbjpvcGVuIHNlc2FtZQ==
andrhrstv
Post by andrhrstv »
@waltervl i can't believe I've missed this one, thanks for pointing it out, it worked.
