timer function
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pgas37
timer function
Post by pgas37 »
I have created a script to compare the gross/net supply of solar panels to the electricity consumption from the grid, resulting in the net supply/consumption of a day. Because there is a constant change in supply and consumption, the script generates an up-to-date report every few seconds and therefore a very large log file. I wanted to limit that somewhat by building in a timer (2 minutes), but the timer function does nothing.
Can anyone tell me what i'm doing wrong here?
Paul
		timer = {
			'every 2 minutes'
		devices = {
			'Energy xxx60',
		    --'kWh Meter Inverter 1',                          	-- 'Power L1 Inverter 1' -- solar kwh bruto
	        'ModbusTcp - Total Energy',
	logging = {
		level = domoticz.LOG_INFO,
		marker = '2solar=====================',
	execute = function(domoticz,device)
	--	domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
	local usage = domoticz.devices('Energy xxx60').usage
	local LeveringNetVandaag = domoticz.devices('Energy xxx60').counterDeliveredToday
	--local SolarVandaag = domoticz.devices('kWh Meter Inverter 1').counterToday
	local SolarVandaag = domoticz.devices('ModbusTcp - Total Energy').counterToday
	local VerbruikNetVandaag = domoticz.devices('Energy xxx60').counterToday
	domoticz.log('Device60 usage actualWatt ................... = ' ..usage, domoticz.LOG_INFO)
	domoticz.log('Device Solaredge: Bruto levering zonnepanelen = ' ..SolarVandaag, domoticz.LOG_INFO)
	domoticz.log('Device60: Verbruik uit electriciteitsnet..... = ' ..VerbruikNetVandaag, domoticz.LOG_INFO)
	domoticz.log('Device60: Netto Levering aan electiciteitsnet = ' ..LeveringNetVandaag, domoticz.LOG_INFO)
	local nettoInternverbruik = SolarVandaag - LeveringNetVandaag
	--local eigenverbruik60 = countertoday60 - LeveringNetto
	local nettoverbruik_levering = VerbruikNetVandaag - LeveringNetVandaag
   -- domoticz.log('nettoverbruik ............................... = ' ..nettoverbruik, domoticz.LOG_INFO)
    T1 = ('+ Bruto levering zonnepanelen. = '..SolarVandaag.. '</u><br>')
    T2 = ('- Device60: Netto levering net ... = '..LeveringNetVandaag..'</u><br>')
    T3 = ('= Netto intern verbruikt ..............= '..nettoInternverbruik..'</u><br><br>')
    T4 = ('.........Device60: Verbruik uit net......= '..VerbruikNetVandaag.. '</u><br>')
    T5 = ('....................= Device60: Netto levering net = '..LeveringNetVandaag..'</u><br>')
    T6 = ('.....................+ Netto verbruik/levering........ = '..nettoverbruik_levering.. '</u><br>')
    --T5 = ('........................nettoverbruik in kWh......................... = '..nettoverbruik..'</u><br>')
    domoticz.devices('Netto energie verbruik').updateText(T1 ..T2 ..T3 ..T4 ..T5 ..T6)
    domoticz.devices('Netto Energie opbr/verbr').updateEnergy(nettoverbruik_levering)
Schermafbeelding Netto energieverbruik.png (29.22 KiB) Viewed 305 times
Domoticz version: 2024.7
Re: timer function
If you only want the script to run every 2 minutes you have to delete the on devices trigger section ( devices= {} ) else the script will run on every device change and every 2 minutes.
pgas37
Re: timer function
Post by pgas37 »
Oké,
That simple.
I thought that the timer function, that is first in the script would also be executed first and thus first pause the script for 2 minutes.
RonkA
Domoticz version: 2023.2
Re: timer function
Post by RonkA »
Hi, i saw you are using points trying to align your text.
Try this; replace:
With this in your script;
local message = T1 .. T2 .. T3 .. T4 .. T5 .. T6
local style = '<span style="font-family: Consolas; font-weight: bold; font-size: 14px;">' .. message .. '</span>'
domoticz.devices('Netto energie verbruik').updateText(style)
For more than one space see this page: https://www.domoticz.com/forum/viewtopi ... 09#p314709
SolarEdge ModbusTCP - Open Weather Map - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
pgas37
Re: timer function
Post by pgas37 »
thanks,
but your solution is only a amendment in style.
i replaced the dots by "&nbsp;" which resulted in
Schermafbeelding 2024-05-05 113451.png (35.06 KiB) Viewed 243 times
The adjusted code:
    T1 = ('+ Bruto levering zonnepanelen&nbsp; = '..SolarVandaag.. '<br>')
    T2 = ('- Device60: Netto levering net = '..LeveringNetVandaag..'<br>')
    T3 = ('= Netto intern verbruikt&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; = '..nettoInternverbruik..'<br><br><br>')
    T4 = ('&nbsp;&nbsp;Device60: Verbruik uit net &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;= &nbsp;'..VerbruikNetVandaag.. '<br>')
    T5 = ('- Device60: Netto levering net&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;= &nbsp;'..LeveringNetVandaag..'<br>')
    T6 = ('= Netto verbruik/levering&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;= '..nettoverbruik_levering.. '<br><br>')
    domoticz.devices('Netto energie verbruik #update 2min').updateText(style)
