can I build domoticz from source on android devices?
reza
Domoticz version: 2024.4
Post by reza »
hi guys
i want build domoticz from source on my andriod tablet. Is it possible?
i want have a touch panel with domoticz in one device.
thank you.
Domoticz version: 2024.7
Re: can I build domoticz from source on android devices?
I don't think it is wise to run a server application like Domoticz on a tablet. You better run Domoticz on a seperate small computer like a Raspberry Pi and use the tablet as a remote control. There are apps to connect to your server.
And after a small search I found this, so you can run Domoticz in a docker on your tablet. https://www.domoticz.com/forum/viewtopic.php?t=33230
reza
Post by reza »
waltervl wrote: Tuesday 30 April 2024 15:38 And after a small search I found this, so you can run Domoticz in a docker on your tablet. https://www.domoticz.com/forum/viewtopic.php?t=33230
hi thank you for answer.
I don't want to use Docker, but I want to create, like an EXE file for Windows, an APK file from Source Dumotics for Android devices :roll:
Good luck, you are the expert here. I guess the application is too complex to just port it to android. But you can give it a try, Google around a little bit how to build an APK from a source.
