Ikea Vindstyrka E2112 PM25 and VOC index sensors not created on Zigbee2MQTT plugin
Posted: Sunday 21 April 2024 13:18
by eddieb
I am running latest Z2M and latest domoticz beta.
I added the Ikea Vindstyrka (E2112) to my zigbee network.
The device is picked up by domoticz with just the temperature and humidity sensors.
Screenshot 2024-04-21 at 13.15.00.png (62.34 KiB) Viewed 3455 times
Z2M reports
Screenshot 2024-04-21 at 13.15.47.png (87.95 KiB) Viewed 3455 times
How can I make domoticz add the PM25 and the VOC index sensors ???
Re: Ikea Vindstyrka E2112 PM25 and VOC index sensors not created
Posted: Sunday 21 April 2024 15:00
What integration do you use for Zigbee2MQTT? Your signature states noder-red and mqtt??
Posted: Sunday 21 April 2024 15:34
by eddieb
Hi @waltervl
plain zigbee2mqtt and than with
Zigbee2MQTT Plugin (v. 3.2.0-beta)
Plugin to add support for zigbee2mqtt project
in domoticz
Posted: Sunday 21 April 2024 18:56
Ok, than you have to ask it tho the plugin owner. Only that plugin owner does not actively support the plugin anymore. Only if someone else creates a proposed code change he will accept it.
You can also change to the native Domoticz MQTT Autodiscover integration with Zigbee2MQTT. Perhaps it is supported there.
Re: Ikea Vindstyrka E2112 PM25 and VOC index sensors not created on Zigbee2MQTT plugin
Posted: Sunday 21 April 2024 19:42
by eddieb
Do I loose every zigbee device while switching to autodiscover ?
Any tips ? suggestions ?
Posted: Monday 22 April 2024 8:34
Check the wiki for instructions https://www.domoticz.com/wiki/Zigbee2MQ ... toDiscover
There are some differences with the plugin on device creation as far as I know. Eg on multi mode buttons (single click, double click, long click etc) you get a switch for every mode instead of a selector switch.
With the replace function you can replace old with new devices so history of sensors and scripts are taken into account.
Posted: Monday 22 April 2024 8:40
by eddieb
Hmm, I installed that new plug on my test domoticz, looking at the same mqtt server as my primary domoticz
The newly installed plug does not regognize at least half ogf my installed zigbee devices ...
The Ikea Vindstyrka does not show up at all ...
Those zigbee devices (temp, etc) do report there values in the primary domoticz and are visible in the zigbee2mqtt screen but do not show up in the autodiscovery ...
Any suggestions how to fix this ?
Posted: Monday 22 April 2024 8:56
by redhouse
Since it seems your are using Node-Red already, it might be a good idea to use that instead. Pick-up the MQTT message from the Ikea Vindstyrka and create a function to split the MQTT message to the separate devices (IDX's). That way, you don't have to depend on the owner/maintainer of the plug-in. I did the same for the Ikea Vindrikting devices a couple of years back. Just an idea :-)
Posted: Monday 22 April 2024 9:13
eddieb wrote: Monday 22 April 2024 8:40 Hmm, I installed that new plug on my test domoticz, looking at the same mqtt server as my primary domoticz
As stated in the wiki, the devices will show up when they send data. For battery powered zigbee devices this can take some hours.....
Posted: Monday 22 April 2024 9:34
by eddieb
That is what I said ...
a couple of devices are sending data but they are NOT detected by autodiscovery at all ..
Posted: Monday 22 April 2024 12:12
by gizmocuz
Eddie, long story short.... When using the native MQTT Auto Discovery hardware you will get it working.
Do you get new devices? Yeah of course, it's a new hardware ID...
Can you easily transfer all old devices to the new ones... yes you can
Do you need to adjust some scripts, probably
So best way to do this is when you have some time (hours)
Best thing is, you can run them side-by-side
Posted: Monday 22 April 2024 15:27
by eddieb
Ok, I'll be patient ...
most of the zigbee devices ar present now, creating 91 sensors ...
by pushing the SETUP button on this screen
Screenshot 2024-04-22 at 15.24.43.png (27.04 KiB) Viewed 3355 times
I get the next screen
Screenshot 2024-04-22 at 15.24.59.png (121.19 KiB) Viewed 3355 times
which is empty ...
Is this normal ???
Posted: Monday 22 April 2024 16:49
Yes, this is normal, there only mqtt ad number devices are shown to set other zigbee devices.
The normal devices will be shown in the default device list (menu setup - devices) as you are used to also with the plugin.
https://www.domoticz.com/wiki/Setup_Devices
Posted: Thursday 25 April 2024 8:51
by gizmocuz
Number devices are used by nodes for some settings. (Like a temperature offset)
But most things can just be configured in Zigbee2MQTT via it's web interface
Posted: Sunday 28 April 2024 8:51
by eddieb
tnx for the help so far, migrated to AD. Most things are working...
