Free Domoticz app has stopped working
OldPensionado
Post by OldPensionado »
Hi guys,
Since a week or so I am facing a non working (free) Domoticz app, saying "Oops, no data on server". I've read about a similar problem in this topic https://www.domoticz.com/forum/viewtopi ... ps#p316170
Unfortunately this concerns the premium app and not the free one.
In this topic a solution was presented by jvdz, using NGINX, by means of a "simple" workaround. Although I absolutely do love simple workarounds, I am not familiar with NGINX and I am not intending to use it.
Is there another, hopefully also a "simple", workaround to solve my problem? Should I remove and reinstall the app? Or should I update Domoticz on my Raspberry Pi?
App version (free) 0.2.371 (9474)
Fairphone 5, Android 13
Domoticz on RPi, V 2022.2
Thanks in advance!
RPi 1, model B, Rev. 2; RPi 3B+; RPi Zero; RPi 4B
Raspbian 10 (Buster)
Domoticz V2022.2
Well, such is life. And it's getting sucher and sucher...
Domoticz version: 2024.7
Re: Free Domoticz app has stopped working
Did you look at the app what's new? You need Domoticz 2024.x now.
OldPensionado
I am afraid that I missed that! I will update right away and report later.
Tnx for the tip.
Domoticz V2022.2
OldPensionado
As stated years ago: Read The F... Manual! (And use this forum, hihi.)
Updating Domoticz on my RPi-server did the trick. For the benefit of other users I will describe my actions:
  • Shut down the RPi.
  • My RPi uses a SDcard and a USBstick for booting and operating. So I made backups of both using USB Image Tool from Alexander Beug.
  • Remounting both cards and boot the RPi.
  • Open the webgui of Domoticz on my pc.
  • Setup > Check for Update > Update available version #15889
  • Downloading starts and took about 2 minutes.
  • Argghhh! Error while downloading. Check your internet connection. Try again later.
  • Using SSH (Putty) I restarted Domoticz on the RPi.
  • Webgui Domoticz > Check for Update > No Update Available! What is happening here?
  • Fortunately I examined the webgui a bit closer and voilà: version 2024.4 was running!
  • Final check: the Domoticz app on my smartphone runs perfectly without any problems.
Lessons learned: see above.
And many thanks to waltervl!
Domoticz V2022.2
ronalddevos
Post by ronalddevos »
A similar problem here: on my android domoticz app the dashboard give "oops! No data on dmoticz server" most of the time (98%). All other tabs (switches, tempearture, ...) work fine, only th dashboard fails.
domoticz 2023.4 on windows
domotica app 0.2.376 (9591) on android
Suggestions?
akamming
Post by akamming »
when will the iphone app be updated? hasn't been working for a long time now...
ronalddevos wrote: Monday 01 July 2024 11:06 A similar problem here: on my android domoticz app the dashboard give "oops! No data on dmoticz server" most of the time (98%). All other tabs (switches, tempearture, ...) work fine, only th dashboard fails.
Suggestions?
Never heard of this. Dashboard is working on a browser GUI?
ronalddevos
Dashboard working on a browser, yes
jvdz
Domoticz version: 4.107
Post by jvdz »
Probably an incompatibility with the new API's?
Have you checked the log of API warnings when you get the OOPS in the APP?
ronalddevos
No API errors.
After struggling with this for the last months or 2, it now seems to be working 80% of the time.... No change, no restarts..
I'll monitor what happens, but I am baffled...
Do you allow remote access from outside your home network to your domoticz server? Perhaps that configuration is off...
