script doesn't do what I want
Posted: Monday 15 April 2024 14:30
by Jan Jansen
		devices =
		    'Bed José (Action)_single',                                         -- zigbee push button
		    'Bed MJ (Action)_single',                                           -- zigbee push button
		    'Beweging slaapkamer (Pir)',                                        -- zigbee motion sensor
	    logging =
            level = domoticz.LOG_DEBUG,
            marker = 'nachtverlichting slaapkamer',
	execute = function(dz, device)
	    local bj = dz.devices('Bed José (Action)_single')
	    local bmj = dz.devices('Bed MJ (Action)_single')
	    local nvs = dz.devices('Nachtverlichting slaapkamer')         -- zigbee outlet
	    local pirslpkmr = dz.devices('Beweging slaapkamer (Pir)')
	    dz.log('Beweging slaapkamer (Pir),                 state: ' .. pirslpkmr.state, dz.LOG_DEBUG)
	    if  (bj.state == 'On' or bmj.state == 'On' or pirslpkmr.state == 'On') and nvs.state == 'Off' then
	         nvs.switchOn().forMin(10)
	    elseif (bj.state == 'On' or bmj.state == 'On') and nvs.state == 'On' then
	        nvs.switchOff()
When using the push buttons, the script works as intended. When the PIR is activated, the "Nachtverlichting" turns 'On' as intended.
2024-04-15 13:16:39.655  Zigbee2mqtt: Light/Switch/Switch (Beweging slaapkamer (Pir))
2024-04-15 13:16:39.681  Zigbee2mqtt: General/Voltage (Beweging slaapkamer)
2024-04-15 13:16:39.821  Status: dzVents: Info: Handling events for: "Beweging slaapkamer (Pir)", value: "On"
2024-04-15 13:16:39.825  Status: dzVents: Info: nachtverlichting slaapkamer: ------ Start internal script: Script #1: Device: "Beweging slaapkamer (Pir) (Zigbee2mqtt)", Index: 251
2024-04-15 13:16:39.825  Status: dzVents: Debug: nachtverlichting slaapkamer: Beweging slaapkamer (Pir),                 state: On
2024-04-15 13:16:39.825  Status: dzVents: Debug: nachtverlichting slaapkamer: Constructed timed-command: On
2024-04-15 13:16:39.825  Status: dzVents: Debug: nachtverlichting slaapkamer: Constructed timed-command: On FOR 600 SECONDS
2024-04-15 13:16:39.825  Status: dzVents: Info: nachtverlichting slaapkamer: ------ Finished Script #1
2024-04-15 13:16:39.828  Status: EventSystem: Script event triggered: /home/mj/domoticz/dzVents/runtime/dzVents.lua
2024
After PIR activation, the Domoticz motion sensor (switch) remains 'On' for 1 minute. It then switches 'Off' and the "Nachtverlichting" also switches 'Off' (the 'Nachtverlichting' was intended to only switch off after 10 minutes). The log then shows
2024-04-15 13:17:47.945  Zigbee2mqtt: Light/Switch/Switch (Beweging slaapkamer (Pir))
2024-04-15 13:17:47.959  Zigbee2mqtt: General/Voltage (Beweging slaapkamer)
2024-04-15 13:17:48.089  Status: dzVents: Info: Handling events for: "Beweging slaapkamer (Pir)", value: "Off"
2024-04-15 13:17:48.094  Status: dzVents: Info: nachtverlichting slaapkamer: ------ Start internal script: Script #1: Device: "Beweging slaapkamer (Pir) (Zigbee2mqtt)", Index: 251
2024-04-15 13:17:48.094  Status: dzVents: Debug: nachtverlichting slaapkamer: Beweging slaapkamer (Pir),                 state: Off
2024-04-15 13:17:48.094  Status: dzVents: Debug: nachtverlichting slaapkamer: Constructed timed-command: Off
2024-04-15 13:17:48.094  Status: dzVents: Info: nachtverlichting slaapkamer: ------ Finished Script #1
2024-04-15 13:17:48.097  Status: EventSystem: Script event triggered: /home/mj/domoticz/dzVents/runtime/dzVents.lua
2024
I don't understand why the "Nachtverlichting" turns 'Off' when the Domoticz motion sensor (switch) turns 'Off'. Nowhere in the script is this requested. What's going wrong?
Thanks in advance!
Re: script doesn't do what I want
Posted: Monday 15 April 2024 14:45
by jvdz
Jan Jansen wrote: Monday 15 April 2024 14:30 I don't understand why the "Nachtverlichting" turns 'Off' when the Domoticz motion sensor (switch) turns 'Off'. Nowhere in the script is this requested. What's going wrong?
Thanks in advance!
Well, the PIR Off does trigger an event, so the second if is somehow true at that time the PIR goes off:
   nvs.switchOff()
So could it be that either bj.state or bmj.state is still "On" at that time?
Maybe add a debug log message to the code to check that?
Posted: Monday 15 April 2024 16:36
by Jan Jansen
@jvdz,
You're right, that's the problem.
I tried to solve it with:
elseif (bj.state == 'On' or bmj.state == 'On') and pirslpkmr.lastUpdate.secondsAgo > 70 and nvs.state == 'On' then
	        nvs.switchOff()
But that change does not solve the problem
Posted: Monday 15 April 2024 17:02
by jvdz
Just so I understand what you like to accomplish: This second test is to be able to interrupt the 10 minutes on by pressing one of the 2 buttons so it should only do something when the event is originating from either of those buttons?
Posted: Monday 15 April 2024 19:04
by habahabahaba
May be
            if pirslpkmr.state == 'Off' then
                nvs.cancelQueuedCommands()
	        nvs.switchOff().afterSec(600)
                nvs.switchOff()
Posted: Monday 15 April 2024 19:53
by Jan Jansen
First of all, thank you both for your time and attention.
What do I want to achieve:
1. Lighting on for a maximum of 10 minutes after PIR activation or after activation of 1 of the 2 push buttons.
2. Lighting off after activation of 1 of the 2 push buttons.
The adjustment suggested by @habahabahaba does not work as intended.
2024-04-15 19:35:15.956  Zigbee2mqtt: Light/Switch/Switch (Beweging slaapkamer (Pir))
2024-04-15 19:35:15.988  Zigbee2mqtt: General/Voltage (Beweging slaapkamer)
2024-04-15 19:35:16.133  Status: dzVents: Info: Handling events for: "Beweging slaapkamer (Pir)", value: "On"
2024-04-15 19:35:16.138  Status: dzVents: Info: nachtverlichting slaapkamer: ------ Start internal script: Script #1: Device: "Beweging slaapkamer (Pir) (Zigbee2mqtt)", Index: 251
2024-04-15 19:35:16.138  Status: dzVents: Debug: nachtverlichting slaapkamer: Beweging slaapkamer (Pir),                 state: On
2024-04-15 19:35:16.138  Status: dzVents: Debug: nachtverlichting slaapkamer: Bed José (Action)_single,                  state: On
2024-04-15 19:35:16.138  Status: dzVents: Debug: nachtverlichting slaapkamer: Bed MJ (Action)_single,                    state: On
2024-04-15 19:35:16.138  Status: dzVents: Debug: nachtverlichting slaapkamer: Constructed timed-command: Off
2024-04-15 19:35:16.138  Status: dzVents: Info: nachtverlichting slaapkamer: ------ Finished Script #1
2024
Posted: Monday 15 April 2024 20:00
by jvdz
Jan Jansen wrote: Monday 15 April 2024 19:53 2. Lighting off after activation of 1 of the 2 push buttons.
In that case I think you should test for the device that triggered the event by reading the event data.
Something like this maybe ( I am not able to test this easily)
elseif (device.name == 'Bed José (Action)_single' or device.name == 'Bed MJ (Action)_single') and nvs.state == 'On' Then
	nvs.switchOff()
Maybe this is a nicer/shorter version of your logic using the Event device data:
        if nvs.state == 'Off' and device.state == 'On' then
        elseif nvs.state == 'On' and device.state == 'On' and device.name ~= 'Beweging slaapkamer (Pir)' Then
            nvs.switchOff()
Posted: Tuesday 16 April 2024 9:30
by habahabahaba
		devices = {58, 59, 68}, -- Idx of 2 buttons and Motion sensor, change to yours
	logging = {
        --local nvs = domoticz.devices(25) -- idx of your zigbee outlet
        if (device.name =='Bed José (Action)_single' or device.name =='Bed MJ (Action)_single'  and device.state == 'On' ) then
            if nvs.state == 'On' then
                nvs.switchOff()
                nvs.switchOn().forMin(10).checkFirst() -- CheckFirst is needed cause some time forMin() doesn't work without it
        elseif (device.name =='Beweging slaapkamer (Pir)' and device.state == 'On') then
Posted: Wednesday 17 April 2024 14:23
by Jan Jansen
jvdz wrote: Monday 15 April 2024 20:00
            nvs.switchOff()
Thanks, this is what I was looking for. Using device.state was new to me
