Error: MQTT: Unknown command received: setsetpoint
Posted: Wednesday 10 April 2024 21:38
currently I'm developing some Node-Red-Flows in order to integrate Homematic-IP-Devices in Domoticz.
I tried this first with a Windor-Sensor and it works fine.
Second try is to integrate a thermostat.
When trying to update the Setpoint of the virtual Thermostat in Domoticz via MQTT I get the above error.
Strangely the same command (setsetpoint) is working fine when using the respectice JSON-Call in a webbrowser.
Is this a bug in the MQTT plugin ?
