How can I add HikVision camera (problem with CORS)?
fantom
Post by fantom »
In postman i can call
http://IP:PORT/ISAPI/Streaming/channels/101/picture
with basic or digest auth, and i see a image.
In Domoticz I set this data, and when i click "Test connection" i don't see picture.
In network status i see "(blocked:origin)"
How can I fix it?
habahabahaba
Domoticz version: 2024.4
Re: How can I add HikVision camera (problem with CORS)?
Post by habahabahaba »
I have 3 hikvision cameras. All works fine in Dz (etc. in Dzvents, 'http://<user>:<pass>@192.168.0.85/ISAPI ... 01/picture' - for taking picture)
May be Port number, user, password? https instead of http?
fantom
Post by fantom »
I try set parameters in configuration->Cameras
I am providing exactly the same ones as via postman.
But error is weird. Its not something like 401,404,405 etc. Its "blocked origin".
Is the ImageURL correct? should be: /ISAPI/Streaming/channels/101/picture
Perhaps strange characters in userID or password?
fantom
Post by fantom »
Yes - url corrected - like in first post.
Zero weird characters in user/password.
Did you try ImageURL without the first slash?
fantom
Post by fantom »
I can set anything, and i always see in network:
picture (blocked:origin)
This is problem with CORS or something like that (I think).
habahabahaba
screenshots?
fantom
Post by fantom »
I can change anything (ip, user, path etc) and i have always this same error in network.
In Postman i call http://192.168.1.xx:80/ISAPI/Streaming/ ... 01/picture and I can get picture.
screenshot
screenshot
habahabahaba
May be try to update the firmware of camera?
And did you try to get image from dzvent-script?
fantom
Post by fantom »
This is problem with routing/proxy or something like that i think
Camera have the newest firmware.
I don't use LUA :(
This preview is sometimes not working on this page. Perhaps check the normal functionality. Eg add a trigger switch and have the screenshot sent by email.
kimot
Domoticz version: v3.8153
Post by kimot »
First - I see your address "/channels/1/pic..." and for me works "/channels/101/pic..."
Second - Hikvision in manual recommends using strong passwords, but beware, you cannot use some characters in the http address.
For example my own painful experience when testing stream with VLC. My password contains a capital letter and a + character and VLC converted everything to lowercase letters before sending the address and removed + character. Therefore, I recommend a simple username and password for testing.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
