How to configure MS-104Z for rocker switch
Posted: Tuesday 09 April 2024 13:01
by njlammerts
I run domoticz latest version and are able to successfully connect/add the Moes MS-104Z device with Zigbee, by holding the button on the MS-104Z for longer time. First it beeps 2 times, but after a longer period of pushing it is continuously beeping until the pairing is completed.
After that I can add the switch to Domoticz and switch on/of my lights
But when I use the normal rocker switch, the light does nothing. I checked the power and signal wire for presence of 220V and that's all ok.
Also the S1 connector is getting the 220V from the switch, but the MS-104Z does nothing with it.
Scherm­afbeelding 2024-04-09 om 12.30.14.png (237.82 KiB) Viewed 5225 times
I followed the instruction as described in the manual https://www.samotech.co.uk/wp-content/u ... Manual.pdf (manual override) but switching on/off the physical switch for 5, 10 or 20 times does nothing.
Does anyone know how to enable the MS-104Z for use with physical switch also?. I tried every setup, but can't get the physical switch to work. The domoticz switch does work fine, but I want to use both
