math.rand gives same results [solved]
ravaoo
Domoticz version: 2024-7
Post by ravaoo »
We have 6 colored lamps in the bathroom. For my kids i want to program a disco mode.
I have 7 defined colors and with math.rand(1,7) for each lamp this should give diferent colors for every lamp (or sometimes the same bij change).
The outcome is that every time most of the lamps have the same color.
On sites about LUA I learned there is a math.randomseed(xxx) to prevent the same results.
With or without math.randomseed results in same colors.
I think calling math.rand in the same second is the reason for giving same numbers. For disco effect i need to do this in a second. 8-)
Is it posible to get real random numbers?
 local hueRoze=53201
        local hueBlauw=46793
        local hueRood=53201
        local hueOranje=65451
        local hueGeel=5159
        local hueGroen=26035
        local hueWit=41490
        local hueWarmwit=8276
        local kleur=1
math.randomseed(os.clock()*100000000000)
        -- lamp 1
        local deUrl='https://1.2.3.4/api/huekey/lights/18/state'
        -- Kies een kleur
                kleur=math.random(1, 7)
                      domoticz.log('Kleur = '..kleur)
      		    if (kleur==1) then
      			    postD = { on = true, sat = 254 , bri = 254 , hue = hueRoze }
                if (kleur==2) then
    			    postD = { on = true, sat = 254 , bri = 254 , hue = hueBlauw }
        	    if (kleur==3) then
      			    postD = { on = true, sat = 254 , bri = 254 , hue = hueRood }
                if (kleur==4) then
    			    postD = { on = true, sat = 254 , bri = 254 , hue = hueOranje }
        	    if (kleur==5) then
      			    postD = { on = true, sat = 254 , bri = 254 , hue = hueGeel }
                if (kleur==6) then
    			    postD = { on = true, sat = 254 , bri = 254 , hue = huegroen }
        	    if (kleur==7) then
      			    postD = { on = true, sat = 78 , bri = 254 , hue = hueWit }
      			domoticz.openURL({
                url = deUrl,
				method = 'PUT',
  			    postData = postD,
				callback = 'return', -- see httpResponses above.
        -- lamp 2
        deUrl='https://12.3.4/api/huekey/lights/19/state'
        -- Kies een kleur
      		    if (kleur==1) then
                if (kleur==2) then
        	    if (kleur==3) then
                if (kleur==4) then
        	    if (kleur==5) then
                if (kleur==6) then
        	    if (kleur==7) then
      			domoticz.openURL({
                url = deUrl,
				method = 'PUT',
  			    postData = postD,
        -- lamp 3
        deUrl='https://1.2.3.4/api/huekey/lights/20/state'
        -- Kies een kleur
      		    if (kleur==1) then
                if (kleur==2) then
        	    if (kleur==3) then
                if (kleur==4) then
        	    if (kleur==5) then
                if (kleur==6) then
        	    if (kleur==7) then
      			domoticz.openURL({
                url = deUrl,
				method = 'PUT',
  			    postData = postD,
        -- lamp 4
        deUrl='https://1.2.3.4/api/huekey/lights/21/state'
        -- Kies een kleur
      		    if (kleur==1) then
                if (kleur==2) then
        	    if (kleur==3) then
                if (kleur==4) then
        	    if (kleur==5) then
                if (kleur==6) then
        	    if (kleur==7) then
      			domoticz.openURL({
                url = deUrl,
				method = 'PUT',
  			    postData = postD,
        -- lamp 5
        deUrl='https://1.2.3.4/api/huekey/lights/23/state'
        -- Kies een kleur
      		    if (kleur==1) then
                if (kleur==2) then
        	    if (kleur==3) then
                if (kleur==4) then
        	    if (kleur==5) then
                if (kleur==6) then
        	    if (kleur==7) then
      			domoticz.openURL({
                url = deUrl,
				method = 'PUT',
  			    postData = postD,
        -- lamp 6
        deUrl='https://1.2.3.4/api/huekey/lights/24/state'
        -- Kies een kleur
      		    if (kleur==1) then
                if (kleur==2) then
        	    if (kleur==3) then
                if (kleur==4) then
        	    if (kleur==5) then
                if (kleur==6) then
        	    if (kleur==7) then
      			domoticz.openURL({
                url = deUrl,
				method = 'PUT',
  			    postData = postD,
To know: i changed the IP and huekey in the code
Running latest BETA on on Docker (Container Manager) in Synology NAS using zwave_js_ui with mqtt. Getting started with homebridge.
Living in an automated house is a survival but it is worth it
willemd
Re: math.rand gives same results
Post by willemd »
What if you run below script? Do you get different color numbers? I do.
		timer = {
			'every minute',				-- causes the script to be called every minute
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
	execute = function(domoticz, timer)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
		for i = 1,100 do
ravaoo
Post by ravaoo »
willemd:
Tested your script
This script gif's me different color numbers!
Then i put your script in my script. Stil different color numbers in your script part and mine almost the same numbers!
Then I put in a for loop of 10 random numbers that i don't use for each lamp. Debugging de list of numbers that i don't use gives me 6 times (number of lamp's) the same row of random numbers.
At last i changed for each lamp de number to loop for not used color numbers. This works
So:
lamp 1 got 1 not used random numbers
lamp 2 got 2 not used random numbers
lamp 1 got 3 not used random numbers
lamp 1 got 4 not used random numbers
lamp 1 got 5 not used random numbers
lamp 1 got 6 not used random numbers
Strange to get the same row of numbers by using math.random (i like to think this is a bug)
But i have created a workaround to willemd who set me on the way.
boum
Domoticz version: 4.10717
Post by boum »
Your use of math.randomseed seems… random. It might overflow integer value and result in a no-op. Or the same value rounded every time so same sequence of generated numbers. Ideally, you should use math.randomseed(os.time()) only once before the whole disco commands.
Also lots of redundancy in your code. Can be shortened to be more easy to read and modify:
 local hueRoze=53201
        local hueRood=53201
        local hueGeel=5159
        local hueWit=41490
        local kleurPost= {
      			    { on = true, sat = 254 , bri = 254 , hue = hueRoze },
    			    { on = true, sat = 254 , bri = 254 , hue = hueBlauw },
      			    { on = true, sat = 254 , bri = 254 , hue = hueRood },
    			    { on = true, sat = 254 , bri = 254 , hue = hueOranje },
      			    { on = true, sat = 254 , bri = 254 , hue = hueGeel },
    			    { on = true, sat = 254 , bri = 254 , hue = huegroen },
      			    { on = true, sat = 78 , bri = 254 , hue = hueWit },
        local lamps = {
            'https://1.2.3.4/api/huekey/lights/18/state', -- lamp 1
	    'https://12.3.4/api/huekey/lights/19/state',         -- lamp 2
            'https://1.2.3.4/api/huekey/lights/20/state',        -- lamp 3
            'https://1.2.3.4/api/huekey/lights/21/state',        -- lamp 4
            'https://1.2.3.4/api/huekey/lights/23/state',        -- lamp 5
            'https://1.2.3.4/api/huekey/lights/24/state',        -- lamp 6
        for i, deUrl in ipairs(lamps) do
            -- Kies een kleur
                local kleur=math.random(1, 7)
                local postD = kleurPost[kleur]
      		domoticz.openURL({
                	url = deUrl,
			method = 'PUT',
  			postData = postD,
additional, are you doing something with callback in OpenURL()? It is not clear from the script you are giving us.
Because if you do react on the callback you have to make it unique eg returnlamp1, returnlamp2 etc.
Else Dzvents will react on the 'return' callback giving random callbacks.
ravaoo
Post by ravaoo »
boum wrote: Monday 08 April 2024 15:19 Your use of math.randomseed seems… random. It might overflow integer value and result in a no-op. Or the same value rounded every time so same sequence of generated numbers. Ideally, you should use math.randomseed(os.time()) only once before the whole disco commands.
 local hueRoze=53201
        local hueRood=53201
        local hueGeel=5159
        local hueWit=41490
        local kleurPost= {
        local lamps = {
            -- Kies een kleur
      		domoticz.openURL({
                	url = deUrl,
			method = 'PUT',
  			postData = postD,
Thanks boum, I dit try without use of math.randomseed and this gives random numbers.
I am stil learning to use lua and dsvents :) Nice optimization for the code! I do like the ipairs bit.
ravaoo
Post by ravaoo »
waltervl wrote: Monday 08 April 2024 16:54 additional, are you doing something with callback in OpenURL()? It is not clear from the script you are giving us.
Thanks again waltervl. You are right!
Creating code, debug, try something, debug, etc. gives a lot of code that should not be there. ;) Now i got it working i can cleanup.
ravaoo
Post by ravaoo »
@ Moderator: leecollings
How do i set a subject to [solved]? Or is this a moderator thing?
