Hi!
i have tried several times to migrate to z-wave js ui but with no luck, so im still on open z-wave, i have now a strange problem,
i have set alot of lamps in the house on timers , i have set them to off-delay, this has worked pretty good, but now domoticz cant see if the light is on or off, if i turn on the beroom light the state in domoticz wont change to on, it still says off, i can turn on or off the lights from domoticz , but the status wont change if i turn on the light manually from the swith.
any idea what to do?
open z-wave problem
tjabas
Re: open z-wave problem
to clearify what i mean is that, if i turn the physical button/ the wallswith to on, then the status in domoticz wont change to on, it will still be off.
any idea of how this could be fixed?
in domoticz i can turn on oand off the same light without any problem and the status changes as it should, but not using the wall switch.
