Itho Wifi Controller Python plugin
galadril
Domoticz version: latest
Post by galadril »
I just started a basic Python plugin to send commands to the Itho Wifi Controller.
Its currently only to push new commands to the module, not read the current state.. but please adjust if needed ;)
https://github.com/galadril/Domoticz-Itho-Wifi-Plugin
More info about the module:
https://github.com/arjenhiemstra/ithowifi/wiki
I tried to create an OpenApi spec around the module's api here:
https://github.com/arjenhiemstra/ithowifi/issues/214
Device:
Please adjust the script if needed.
DBND
Re: Itho Wifi Controller Python plugin
Post by DBND »
At the moment, this plugin crashes my webfrontend. Looking at the logs, this may be due to some python dependencies.
Domoticz Version: 2025.2 (build 16818)
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
So may need some checking/reference before install.
It would help that you note your findings on the plugin in more detail as it looks like this should work on any python version....
Perhaps the ithowifi module has more dependencies but the plugin definitely has no, only loads JSON and requests.
